wrong Firmware
i have installed a wrong firmware on my mp4 player(it's von from weike)!
my computer can detect it but only as an usb-stick.I can't turn it on. here's the website of my mp4 player http://www.szmicrotech.com that's my mp4 player http://www.szmicrotech.com/918a.jpg ps:sorry for my bad english ! i am a albanian who live in germany |
Re: wrong Firmware
i only need the wright firmware for this.
if someone here have one with an other name then please contact via pm! |
Germany,
Have a look at the Firmware section of the DOWNLOADS area to see if you can find a suitable player. Most of the players looks different but have similar boards. The best way to check is to compare the startup, ending and main menu pictures to see if they are the same as yours. Good luck. |
mine has no games but ebook and fm function |
Germany,
Do you remember what the opening and ending animation was? Most of the players use very similar boards with only slight modifications, mainly for the buttons. So if you are desperate, you can try the others if you want to take the risk. There are instructions on how to recover your player if it's dead anyway. Good luck and hopefully someone can upload a firmware for your player. |
Re: wrong Firmware
Re: wrong Firmware
my computer can find my mp4 player and the firmware upgrade tool also. |
Re: wrong Firmware
Re: wrong Firmware
try this one:
http://www.s1mp3.org/files/firmware/fw_from_flash/MP-693C-S_(v3.5.35_merged_-_FULL).7z worked fine for me, just 1 minute before. or try some of these: http://www.s1mp3.org/en/downloads_fw.php#oled |
| All times are GMT -7. The time now is 2:33 pm. |
