Fake Ipod 1.5 Screen - Problem with Firmware (Blue Screen)
Old 26th May 2006, 3:04 am
Default Fake Ipod 1.5 Screen - Problem with Firmware (Blue Screen)
Hello
I bought a MP4 (like Ipod 1.5 screen) 1 Go
Here you have the pic :
http://www.mympxplayer.com/album_picm.php?pic_id=38
I found the good firmware on mympxplayer :
http://www.mympxplayer.com/dload.php...le&file_id=117
Moreover The MP3 Upgrade tool said the upgrade was a success !!
The problem is I see only a blue screen. But the MP4 works : I can put some musics or folders without problem because windows recongnize it without any problems. I can also listen this music because I remenber what touch I have to put to access to listen the songs (but i see nothing).
So if you can help me ... thänk you in advance.
Sorry for my poor English.
Gilles
Old 26th May 2006, 3:56 am
Default Re: Fake Ipod 1.5 Screen - Problem with Firmware (Blue Scree
Hi Gilles,
Well your nano clone looks the same as mine, and the firmware you downloaded looks to be right as it worked for me, but i know these things can look the same and yet have different components inside.
One suggestion is try updating again but with a different version upgrade tool, I had problems with the one that came with my player but had more luck with version 3.68 or 4.00 both of which can be downloaded in tools section .
http://www.mympxplayer.com/dload.php...r=DESC&start=0
Good Luck.
Terry
Old 26th May 2006, 9:15 am
Thanks for your quick response.
I try with the upgrade tool 4.0 but it doesīnt work ....
I donīt know what happened sniff snifff
Gilles
Old 26th May 2006, 5:56 pm
I do not know what version you first tried but 3.68 seems to be a little more stable than 4.00.
You could try this one http://www.mympxplayer.com/dload.php...77773f7e087b38
It is a mod I did of my original firmware.
Hope it helps.
Old 27th May 2006, 2:53 am
Thanks for your help
The update tool say "update success" .... but blue screen ... itīs really strange (itīs the same thing with the version 3.68 or 4.00)
Old 27th May 2006, 9:57 am
Guest
Posts: n/a
Hey Gilles, a couple more options you can try, after reading many posts on S1mp3.org forums it appears some have had success by first reformatting their players before flashing the firmware.
Also most of the firmware on the net are not full firmware files but partial dumps. I found this link to a firmware file that has the same image content as the first one you downloaded but is claimed to be a full firmware file might be worth a try.
http://www.alexejw.net/firmware/MP-6...5.35%20full.7z
Fingers crossed,
Terry
Old 2nd Jun 2006, 2:33 pm
Sorry for my late response but I was very busy !!!*
I don't have found the problem yet (I resume my problem)
ATJ2085W
MP-693c-SL MAIN v1.3 2005.12.14
Samsung 610 K9K8G08U0M
QQ 1GB
Windows recognize my MP4 .... but i have still a Blue screen or black screen (when I puit the Firmware CDT sd4284-h_v2.0_7 = it's the version 3.042
I don't have some solution ... please help me
Gilles
Old 2nd Jun 2006, 5:10 pm
ATJ2085W
QQ 1GB
Gilles
Gilles, sounds to me like you have not found the right firmware for your player. You have stated MP-693c-SL here are some firmwares with the same code.
http://www.mympxplayer.com/dload.php...le&file_id=113
http://www.s1mp3.org/files/firmware/..._MP-693C-SL.7z
http://www.s1mp3.org/files/firmware/fw_from_flash/MP-693C-S_(v3.5.35_merged_-_FULL).7z
Old 3rd Jun 2006, 3:19 am
Thanks for your help.
All firmwares you give me works seems working (Upgrade success)
But infortunaly I still got the blue screen.
With this firware CDT sd4284-h_v2.0_7-FM.fw I can go to the "recovery mode" .. black screen and after with this 3.5.37v2.1b FM.fw I can return to a normal mode Blue screen.
Maybe i need an other .fw ... i don't know.
Gil
Old 3rd Jun 2006, 4:33 am
Gil
Gill where are you getting these .fw files from please leave a link.
Fake ipod is blue screen - LKC_9101_01 9.0.50 arifemir Dead Players 3 19th Mar 2008 2:55 am
Big Problem.. MP4, Blue screen. Mergim19 Support and How To 0 28th Jan 2008 8:15 am
fake ipod blue screen ruzan Dead Players 5 6th Apr 2007 6:11 pm
MP4 FW problem, blue screen BlackLightBurns Dead Players 2 9th Feb 2007 3:51 pm
Blue screen Problem eshkblr Dead Players 0 19th Nov 2006 11:31 pm
