U_U Tried changing Firmware
Old 8th Jun 2006, 10:32 am
Default Re: U_U Tried changing Firmware
Hello Totalrecall
I have try this firmware TR_v3.5.37_080606
"Updta success" .. but now i see a Yellow screen with two black strip.
So if you can send me some other firmwares ... it wil be cool.
Thanks.
Gilles
Old 8th Jun 2006, 3:26 pm
I have uploaded some more firmware files, wait for a couple hours before they will appear in the download section.
Hope you have more luck with these ones!
Old 9th Jun 2006, 5:16 am
Totalrecall !!!!!!!!!!!!!!!!!!!!!!!!!!!! :P
Doumou Arigatou gozaimasu !!!!!!!!!!!!
Thanks a million !!!!!!!!! It's ALIVE !!!!!!!!!!!!!!!!
Great firmware it's exactly the one I had before n__n . I did exactly what you said , I formated it with windows in FAT and it worked I even formated 3 times to play with my firmware. tadad1 I used your Window vista type firmware for 3.5.35 with the special program s1res_v16 I took your bmp files and replaced my original bmp firmware files with yours so now it's exactly like yours but it's for 3.5.37 great work of yours.
So I guess with your permission or I could send it to you and you could upload it on the download section.
Really thanks everybody for your help^^ I was on the edge of buying a new one >___< .
Great forum and great site
Old 9th Jun 2006, 5:38 am
Kuronami
Glad you find the site useful.
What firmware from Totalrecall did you use? Just so I can keep an eye out for it next time someone else askes a similar question.
Old 10th Jun 2006, 6:43 am
Fibnally .... I Have try one whick works after blue screen :
MP-693C-SL-Main V1.3
http://www.megaupload.com/?d=NJR37WNT
  #16 (permalink)
Old 10th Jun 2006, 7:18 am
skaterfou, congratulations man, is it working fully. I hope so, well done
Cheers M8
  #17 (permalink)
Old 10th Jun 2006, 11:44 am
Hi @Kuronami: I'm happy for you that you managed to re-activate your player.
I'm also interested to know which firmware did the trick, as specially if it is the one I slightly altered.
  #18 (permalink)
Old 19th Jun 2006, 7:12 am
Totalrecall, I simply used the firmware you gave me^^.
- I aM OnlY ThE NOiSe ON ThE wIReS -
White screen, doesn't get recognised after changing firmware fish neck Firmware 7 16th Mar 2008 7:47 pm
Firmware - changing functions / behaviors ollip Mods and Themes 1 21st Feb 2007 6:47 pm
Changing my Firmware images?. Pocket_Nano General Discussion 4 27th Sep 2006 7:48 pm
Why changing your firmware?? Zephyron General Discussion 8 9th Sep 2006 4:29 pm
Changing firmware from v3.5.35 to another Bobby21 General Discussion 3 28th Jul 2006 9:18 am
