please help me
Old 8th Jun 2006, 4:26 am
Default Re: please help me
:? Dear arish_06,tadad1
i dont have the .fw version of my original fw. i have only .bin version. i found from a site that my original version is 3.2.16. can you please send me the original recovery fw. i have been trying with3.5.35&3.35.37. but one time igot the result. the first time when i tried to up grade with 3.5.35.bin mp3 player utilities showed " FIRMWAREUPGRADE WAS SUCCESSFULL". Then i restarted my player. then windows detected it as a flash drive. but memory was ony 350 kb. the i formatted my player as instructed in the user manual. then the memory increased to 105 mb. then i upgraded it with the fw that i have back uped earlier from the player. the again display went dead and windows failed to detect my player. i repeated the shorting steps and at last windows detected it as adfu again. then only i came to know that the original version of my fw was 3.2.16.fw. can any one send that link to me.pleeeeeeeease.
[sreejith51]. ( please neglect the spelling mistakes)
thank you for the helps and supports. :?
Old 8th Jun 2006, 4:53 am
sreejith51, the only full firmware I have is 3.2.13, it is from a copy of a cd that I found on a Chinese web site and has 2 versions with or without FM Radio. If you want to give it a try I will upload it to Rapidshare for you.
Old 8th Jun 2006, 5:42 am
yea, tadad1 ,if you upload it and send me a link it will be very helpful for me. please upload it and send me a link. Once again thankyou for your helps.
Old 8th Jun 2006, 5:58 am
sreejith51, here is the link
http://rapidshare.de/files/22528642/...ull_CD.7z.html
I hope it helps.
Old 8th Jun 2006, 10:58 am
sreejith51, if the firmware tadad1 gave you doesn't seem to work, try the firmwares from s1mp3.org if you haven't already.
There's a bunch of 3.2.16 firmwares...maybe you can find one that works.
Here's the link:
http://s1mp3.org/en/downloads_fw.php...140873da81bd70
It would be easier if you could obtain your board id and try to match it with the firmwares on the site but if you don't wanna open up your player, just choose various firmwares and see if you can at least get it out of recover state and fix your memory issue.
Let us know how it goes.
Don't make the same mistake I made! Always...
your F I R M W A R E :!:
  #16 (permalink)
Old 9th Jun 2006, 10:37 am
:? yea, i have updated with the recovery software given by arish_06. now windows is detecting my player as a fla sh drive . now iam getting a bright dis play. but menu and all are not appearing. What should be the next step. please help me.( but memory is decreased to 108 mb from 256 mb). shall i update my player with the dump file that i have extracted before using s1fwx tool. please give me a suggession.
thank you very much for yr helps arish_06&tatad1. :?
[you]
  #17 (permalink)
Old 9th Jun 2006, 10:50 am
hmmmm...the memory decrease seems pretty weird.
Just roughly how many times have you formatted your player if you have since you purchased it?
If you used a firmware from s1mp3.org, which one did you use? Maybe the firmware's taking up some memory. Check the size of that firmware? ...well it shouldn't be upto 100MB so I am pretty sure that's not the problem.
Maybe the firmware you're using is designed for 128MB player so it is reporting back memory around 100MB.
Are you talking about the dump firmware that was giving you trouble before?
If yes, then upgrading your player with that won't help because it may put it back to recover state.
For now, keep trying with similar firmwares and see if you can find one that fixes the problem.
  #18 (permalink)
Old 10th Jun 2006, 10:41 am
Yes arish_06, it is the same fw caused widows not to detect my player. But this was the original fw. its version is 3.2.16.i have extracted from my player before it went dead. but now it is not working for me. can you suggest a reason. i recovered my player with 3.5.35 merged .mp3 player utilities shows like this.
Device name: S1 MP3 player.
Productor :Wilson CO.Ltd
Version :3.5.35
[you]
jeccec51@hotmail.com
