MP4 from Marcsonic - APPLE M-V2 - need help with firmware
Old 8th Jun 2006, 10:48 am
guivarrichio, thanx for the descriptive pictures.
I don't know if this would help but try uninstalling the mp3 utilities and installing it again.
I wonder why it says "check if device is connecting." :?:
Does your player behave weirdly during the upgrade...as in does it keep turning on and off if you let it be...
Maybe there's something interupping the usb connection...did you check if the usb cable was properly connected and all? And make sure no buttons are pressed on the player during the upgrade.
Don't make the same mistake I made! Always...
your F I R M W A R E :!:
Old 8th Jun 2006, 11:21 am
Default Re: MP4 from Marcsonic - APPLE M-V2 - need help with firmwar
Arish, Thank you for everything, I let a lot of things beside to dedicate some time to put this to work again, and so do you. Thank you very much.
But as we could see we tried, tried and nothing seems to work, I have called the "seller",and this weekend IŽll go to the city I bought to try to get my money back, also, the ON/OFF button is broken, so, 1 more thing to make him give my money back.
He told me he will test and exchange the mp4 per another one.
Cross your fingers please.
see you friend.
Old 8th Jun 2006, 11:26 am
guivarrichio, good luck getting your money back or an exchange mp4.
Maybe the broken ON/OFF button was the problem after all.
Let us know just in case you need further help.
Old 11th Jun 2006, 3:30 pm
Hey guys, listen to this,
I have went to the city to try to get my money back, the seller didnŽt want to give me the money back and neither another player, we talked and talked and I got a foston FS-66 1Gb and R$ 100,00 back, almost $45....
hehehe
Thank you for everythink....
See you guys
Old 11th Jun 2006, 5:20 pm
guivarrihio, sounds like a good deal to me, well done
searching firmware to mp3/4 with an ApplE sign under screen rh79 Dead Players 1 9th Oct 2009 2:33 pm
Apple-M V4 Firmware Samsung 631 k9wag08u1a pcb0 chipset knappix Dead Players 2 10th May 2008 7:49 am
Firmware for MP4 Multimedia player ( Fake Apple ipod) b4idie Mods and Themes 1 8th Mar 2008 6:25 am
Looking for Apple-M V4 Firmware knappix Dead Players 0 19th Dec 2007 7:39 am
Dead Apple-M V2 revived Waimea Dead Players 2 17th Sep 2006 10:01 pm
