[solved] Please Help
Old 13th Jun 2006, 12:28 am
Default Re: Please Help
Thank you all becouse of you my player is working again. I did upgrade it with the firmware from tadad1 and then it was no more just black screen now it was BLUE . Then I formated the player and upgradet with my dump file! Thanx tadad1.
Old 13th Jun 2006, 12:54 am
Adrian, good to hear that your player is working again, I am glad my little experiment helped.
If you get a chance please edit your original post and add (Solved) to the title.
Cheers
Old 13th Jun 2006, 2:38 pm
Default Re: [solved] Please Help
Hi Adrian and tadad1
My mp4 player is the same as Adrian,s. I was wandering could you post your dump file and tadad1 could you post your 3.5.37 file as i can,t seem to get it of rapidshare as i tried different firmware now i have a black screen i was hoping to do what Adrian done.
thanks
Old 13th Jun 2006, 5:49 pm
soggy, have uploaded the firmware to site, you will be able to download it when Binh has approved it.
I have called it Full Version 3.5.37. Hope this helps you get your player going again.
Old 14th Jun 2006, 12:30 am
I will upload my dump file just tell my how.
  #16 (permalink)
Old 14th Jun 2006, 9:07 am
Default [solved] mp4 player back to the blue screen
Hi tadad1
I tried your firmware and i got my mp4 player back to the blue screen.
Hopefully i can get Adrian's dumpfile to try that i don't know how to upload files myself either.
thanks
  #17 (permalink)
Old 14th Jun 2006, 9:28 am
Hey soggy, thats good news, you are only one firmware flash away from recovering your player, hope Adrians works for you.
To Upload you need to go to the Download\Firmware\Uploads by Members and you will see an upload button at the top of the page.
The download will not be able to be downloaded until Binh approves it.
Good Luck Man
  #18 (permalink)
Old 14th Jun 2006, 9:34 am
Thanks tadad1
i hope it works too and i hope Adrian gets to upload his dump file.
cheers
  #19 (permalink)
Old 14th Jun 2006, 9:46 am
soggy, send him a personal message with your email address and get him to send it to you.
  #20 (permalink)
Old 14th Jun 2006, 12:14 pm
Hi tadad1
I sent Adrian a personal message with my email address so if you are reading this Adrian check your messages please.
thanks
