-   -   [solved] Please Help (http://mympx.org/forum/dead-players/33256-solved-please-help.html)
soggy 15th Jun 2006 9:29 am
Re: [solved] Please Help
Hi Adrian
thanks for uploading your file but i had no luck still blue screen. my mp4 player must be a newer version than yours though they look the same i must need Full Version 3.5.37 firmware. I have tried the posted ones but no go.
thanks to tadad1 for the help and to adrian aswell
Hopefully i will get the proper firmware sometime?
RedXbox500 18th Jun 2006 7:25 pm
Yea man i was upgrading then mp3 stopped working then i found here a upgrade http://www.mympxplayer.com/dload.php...le&file_id=182 that it can recover a dead mp3 player then i upgraded to that then it didnt work so i tried to upgraded back to original then the whole thing stoped working??......
Sisqo 15th Dec 2006 6:48 am
i have this mp4 player http://www.laptopmagazin.ro/upload/1161619718dv18.JPG
it had version 9.0.48 and i tried puting 9.0.50 and it crashed:(where can i find version 9.0.48?please help
i tried different .bin files and only at 9.0.43 says Flash is no responding! and the display turn on and is white..how can i bring it back to life?waiting for a response thanks alot!
Jatechie 25th Jan 2007 7:51 pm
i tried using the ful firmware files but all i get is "read or write device information failed" what i really need is a 3.5.37 v1.1 for a mp-752c-sl main v1.1 knife
maxx0831 23rd Feb 2007 12:10 am
Hey Tadad1 I need your help. I have a nano clone as well it has the firmware 9.0.48. I tried upgrading it but when i upgraded it, my mp3 froze on the loading screen. Now when i turn it on it just shows a bluescreen with the loading icon. Plz help get my mp3 running back again.
Que 23rd Feb 2007 1:23 am
Maxx you killed your player as these new firmwares aren't supported by the current version of the exxtracting/flashing program. Wait for an upgrade.
kharbouche 7th Jul 2007 5:18 am
tenks
Mr.Demetrius 24th Oct 2007 3:21 am
Originally Posted by arish_06";p=&quot (Post 2405)
The tool will detect and display the driver letter.
And what I should do, if programm told me: no device found?
zanpo 8th Jan 2009 2:11 am
hello, any idea where i can download this MP3 Upgrade tool ?
i have a 16 GB mp4 player with 2.8" touchscreen and video camera, i tried to put a new firmware on it because the camera didn't work and now when i turn it on i only get a blue screen :(
so i wanna try this method to put a firmware on it maybe it will work
i only need the MP3 Upgrade tool and the location of the pins to short circuit
pls help if you can
