PLZ help MEEEEEEE
Old 21st Jun 2006, 7:41 am
This firmware might work for you
http://www.mympxplayer.com/dload.php...le&file_id=201
Old 22nd Jun 2006, 10:12 pm
YES Loobyloo is the master. Omg after 100000 fiemweres and resting the mp4 player 1000 times and changing computers. Loobyloo gave me a firmwere and it worked back to the original menu and no black line no nothing it worked perfectly. TX ALOT man where did you get this thing.
PS: Loobyloo is the master lol oh man TX im not going to change the firemwere of this thing angen.
Old 23rd Jun 2006, 3:36 am
I'm glad it worked! This is the original firmware from 2gb mp3/mp4 player SC85051C 2006/03/12 ACT_V3.5.35 which I extracted and will now keep forever safe!
Old 23rd Jun 2006, 12:14 pm
lol thats great but there is still a problem for some reson the sleep is not working im truning it on and its not sleeping and when I trun the mp3 player off the sleep gose back too 0. The off time works but not the sleep time I have no idea why. Plz try to fix it because the sceen is staying on all the time and the batteries are draning soo if you can help I would love you enven more TX.
PS: WHY IS THERE NO GAMES :evil: but if you can't get that wtv I just want the sleep to work
Old 25th Jun 2006, 5:15 pm
DJ LiQUiD, Re sleep mode, on some players you need to set the clock for the sleep mode to function properly. Try these settings:
LCDset>Darkle=30
LCDset>Black=30
Power off>Off time=0
This should turn your LCD off after 30 sec, you can reduce that in 5 sec amounts if you wish.
If you are turning your player of at the On\Off switch it will reset your clock and settings to default every time you do this. To turn your player off hold the Play button for a few seconds.
