PLZ help MEEEEEEE
Old 13th Jun 2006, 10:07 pm
Default PLZ help MEEEEEEE
Hello I have a big problem I got a mp4 player from ebay this one http://cgi.ebay.com/1-GB-Mini-MP4-1-...QQcmdZViewItem anyways I wanted to change the firmware. I think thats when everything whent worg well I wen to black screen to somthing that looked like the old menu but it was very had to see anything and then I whent back to black screen and then to a blue screen. Now I have no idea on what to do its a blue screen and I think the players is wroking but I can't seen anything. I when to all the forums in this place any I hade alot of help but now its still now working.
Old 13th Jun 2006, 11:29 pm
Well now I got it working with a menu but its to bight I can see it well I tried editing it with FirmwareModify but its working the file was TR_v3[1].5.37_080606 it works but can't see anything. I found an other one that I edited and it workes and I can see well but there is to big black horinzontal lines on the screen one on the top and one in the midell someplace. That file name is original all the other firmwere do not work they give me blue screens anyways if any one has on that work and dosent give any problems plz tell me TX
Old 14th Jun 2006, 12:03 am
DJ LiQUiD, try repairing the firmware (the one that gives you the black lines) using the s1fwx tool from this site. Then upgrade with the repaired firmware. Maybe this will help solve the problem.
What was your original version? Maybe I can try finding you a compatible firmware.
By the way, which firmware were you talking about when you said you could see but it was too bright? Did you try adjusting the brightness of the lcd? If you still have that firmware, there's a firmware modifier tool on this site that allows you to change the contrast of the screen. Maybe that will help solve your problem.
Let me know if this helps 8)
Don't make the same mistake I made! Always...
your F I R M W A R E :!:
Old 14th Jun 2006, 12:33 am
well nothing s1fwx did not work the repaired firmware is doing the same thing. Also the firmware that was to bight dosent change in the firmware modifier and I can't change it in the lcd setup. Anyways the original version is 3.5.35 and yes I tred all the firmware in this place nothing works.
Also the files are http://www.mympxplayer.com/dload.php...ile&file_id=80 this one is the one that is to bight and http://www.mympxplayer.com/dload.php...le&file_id=166 this is the one with the black lines.
Old 14th Jun 2006, 8:00 am
yay new problem well today I go up and tired this agen. Well to my suprize the the player is not connecting to the computer. I tried everything I even did this http://www.s1mp3.org/en/docs_deadrec.php
but the player still works somehow. Its opening up and playing music with that firmware I got that had a black srtip on it. But thing is that it is the computer is decting the player and its having prblems with the driver. Now I don't know why but I tried uninstalling the drivers and reinstalling them and still nothing. Also when I connected to the usb its just restarting over and over agen and windows is telling me that there was an eror and could not connect somthing somthing bla bla bla. I don't know what to do any more.
Old 14th Jun 2006, 8:45 am
DJ LiQUiD, seems like you have a problem similar to the problem on this forum:
http://mympxplayer.com/viewtopic.php?t=425
Take a look at this post if you like and see if they find a solution.
Was the computer detecting your player fine before with the black striped firmware?
Have you tried with a different usb cable, etc.?
Old 14th Jun 2006, 7:28 pm
well its all over now the player is not turing on anymore I have no idea what hapend but I checked with the volt meeter and it seems good the battery is good and the curcit seems good but the player is not turing on no screen no usb connection nothing TX arish_06 for all your help if there is anythig els you can help me with it would be great anyways im going to talke with the ebay guy see if I can get a other one.
Old 14th Jun 2006, 7:40 pm
DJ LiQUiD, You need to start from scratch and short the chip to reset it.I have posted the steps I used to recover a dead player here with links to the firmware I used:
http://www.mympxplayer.com/viewtopic...r=asc&&start=0
You need to keep repeating the process until you find the correct firmware
Old 14th Jun 2006, 11:32 pm
Well I finaly got it back to making it work but im still having broblems with firmware im not going to repet my slef because its the same thing as the treed post so if any one know anything about that plz help
Old 14th Jun 2006, 11:46 pm
DJ LiQUiD, your only solution is to keep trying different firmware till you find the correct one. What did the boot and shutdown screens look like?
What games did it have?
Did it have a flower theme?
If you give some details finding the firmware will be easier.
