installed incorrect firmware and it doesnt turn on
Old 14th Jun 2006, 5:54 pm
Default Re: installed incorrect firmware and it doesnt turn on
thanx but i tried all, i also need orginal firmwares, dump firmwares dont work. i think i have to buy a new one
Old 14th Jun 2006, 7:16 pm
phantomddl, check you CD that came with the player it may contain the firmware. Do a search of it for .bin or .fw files.
Old 15th Jun 2006, 4:28 am
phantomddl, I found this one which has the same menu images and music player as yours and someone else has used it to recover their player.
http://www.megaupload.com/?d=NJR37WNT
Old 15th Jun 2006, 6:42 am
it says "flash no responding" i think i should re-install the software, i will do that. and let you know if it works, by the way it writes "dump" i dont think it will work but i will try
i e-mailed to the ebay user which i bought that mp4 player from, and replied:
please download the firmware(mp3Set1_45) from our website (http://www.dcdzc.com/english/down/index.asp)
But its not a firmware :roll:
Old 15th Jun 2006, 7:21 am
phantomddl,
You are right no firmare there, don't even appear to be any MP4 players they all seem to be MP3 players.
What do you mean when you say "by the way it writes "dump""
  #16 (permalink)
Old 15th Jun 2006, 1:57 pm
i meant it for the link u gave me, it has dump.bin in it, as far as i know dump files wont work in recovery mode. anyways i ordered the same mp4 player from ebay now
thanx for your help, i will try to make my mpxplayer alive, somehow.
  #17 (permalink)
Old 20th Jun 2006, 3:09 pm
I have same model so try this, it is the original firmware and was the only thing that worked for me
http://www.mympxplayer.com/dload.php...le&file_id=201
  #18 (permalink)
Old 22nd Jun 2006, 2:31 pm
thanx but it says "invalid firmware upgrade file" it always gives the same error for dump.bin files
MP4 Chip Anyka 3221 Firmware Incorrect waltico Dead Players 2 17th Dec 2009 3:49 am
MP4 ANYKA 3221 firmware incorrect waltico General Discussion 0 8th Jul 2008 6:22 pm
Installed wrong firmware, only shows blue screen tarunvishal Dead Players 1 15th Aug 2007 12:46 am
Installed new firmware, now connects for very little while profile Dead Players 6 1st Jan 2007 11:53 pm
Has anyone installed iPod Nano firmware on their MP4 player? Looking General Discussion 0 7th May 2006 12:15 am
