installed incorrect firmware and it doesnt turn on
Old 14th Jun 2006, 10:01 am
Default installed incorrect firmware and it doesnt turn on
i have that mp4 player:
i installed incorrect firmware and it doesnt turn on anymore, what to do?
Old 14th Jun 2006, 10:05 am
phantomddl, Do you know what version your firmware was?
Also do you have a backup?
Old 14th Jun 2006, 10:14 am
Default Re: Need Serious Help
It was 3.2.16 Wilson. Co.
i disassembled and found the board id: ATJ2085
the player doesnt turn on at all
No Backup(dont know how to back-up)
Old 14th Jun 2006, 10:30 am
phantomddl, I have posted some info on the steps I used to recover a dead player here:
http://www.mympxplayer.com/viewtopic...r=asc&&start=0
I suggest you download a few items from the Download Section under Tools and Firmware as well.
Get a selection of firmware, all the 3.2.16 versions you can find and there are a couple of full firmware versions there as well, they may be different versions but that is ok.
Get a program called s1res, you can use this to open the firmware files and see the images inside. Look for ones where most of the images used in menus etc are similar to yours.
As you do not have a backup trying to finding the right firmware is going to be trial and error. You may have to repeat the process a few times till you find the right one.
Old 14th Jun 2006, 12:44 pm
Also have a look at this post too: http://www.mympxplayer.com/viewtopic...=asc&&start=30
It has instructions on how to short the pins to try to recover your player.
Good luck and let us know if that works or not.
Old 14th Jun 2006, 1:01 pm
It's going good, i can install firmwares now, but i can't find the right one.
CPU: ATJ2085W
Board id:HY27UG084G2M TPCB 620A
ATJ2085v2 doesnt work(that firmware killed my mp4 player :P)
does any one has my firmware version?
Old 14th Jun 2006, 1:19 pm
Have a look here: http://www.mympxplayer.com/dload.php...gory&cat_id=15
People have kindly uploaded the firmware of their ipod look-a-like nanos there. See if you can find the one suitable for your player....
Good luck and let us know how you get on.
Old 14th Jun 2006, 1:34 pm
Default Re: installed incorrect firmware and it doesnt turn on
Thats how my menu looks like, im still looking for the correct one
Old 14th Jun 2006, 5:37 pm
it shows blue screen now, i have searched all the web but i couldnt find the correct firmware. i must repair it somehow
one more pic:
Old 14th Jun 2006, 5:41 pm
phantomddl, try these web pages:
http://www.s1mp3.org/en/downloads_fw.php
http://www.mympxplayer.com/viewtopic.php?t=339
You may find your firmware there.
MP4 Chip Anyka 3221 Firmware Incorrect waltico Dead Players 2 17th Dec 2009 3:49 am
MP4 ANYKA 3221 firmware incorrect waltico General Discussion 0 8th Jul 2008 6:22 pm
Installed wrong firmware, only shows blue screen tarunvishal Dead Players 1 15th Aug 2007 12:46 am
Installed new firmware, now connects for very little while profile Dead Players 6 1st Jan 2007 11:53 pm
Has anyone installed iPod Nano firmware on their MP4 player? Looking General Discussion 0 7th May 2006 12:15 am
