problem in it’s firmware during update
Old 14th Jun 2006, 12:10 pm
Default problem in it’s firmware during update
Hey people,
I got a big problem here,
I had a problem in it’s firmware during the update, and I did’t have a backup of that, so I tryed to use some firmwares that I found in the internet but no one worked successfully. The display is lost...
And how can ı back up firmware...??? PLz help me...
Old 14th Jun 2006, 1:33 pm
murka
What does your player look like?
Have you tried recovering your player? There are various posts already in the "Dead Players" section of the forum from people in similar situation as you.
Have a look at this post here: http://www.mympxplayer.com/viewtopic...=asc&&start=30
This will be helpful for you.
Good luck and let us know if it helps.
Problem in my player after update the Firmware baa1425 Dead Players 18 13th May 2007 8:53 am
Would FW update help my Nanoclone battery draining problem ajh Support and How To 2 29th Dec 2006 12:59 pm
Update of Firmware ajaybcd Dead Players 1 2nd Sep 2006 3:23 pm
update firmware mp4 AX moeshing Support and How To 1 6th Aug 2006 7:18 pm
Problem with Firmware Update Renan Support and How To 6 5th Apr 2006 6:39 pm
