-   -   [solved] removable disk busy, write-lock is activated (http://mympx.org/forum/dead-players/33325-solved-removable-disk-busy-write-lock-activated.html)
lilikopter 16th Jun 2006 10:23 am
I have upgrade my firmware 3.5.35 to an other firmware and the result are my mp4 are dead. So when I try to turn on my original firmware the computer dosen't reconize my mp4 and I can't formated the dics because the mp4 are locked. I have use the S1FWX and he reconize my mp4 but he can't open the firmware because the write-lock is activated. I have try to use mp3 player upgrande tool and the message are same too! Somebody can help me? how I can unlock my mp4 for switch firmware? THANKS!
admin 16th Jun 2006 12:34 pm
If you computer doesn't recognise your player, you might have to consider opening it up and short circuiting it.....
Have a look at the instructions here:
http://www.mympxplayer.com/viewtopic...=asc&&start=30
lilikopter 16th Jun 2006 4:33 pm
its working! thanks!!!!
admin 18th Jun 2006 2:31 am
lilikopter
Great to hear.
What did you do to solve it?
