DEAD PLAYER RECOVERY GUIDE
  #91 (permalink)
Old 28th Jul 2006, 12:50 am
shiloh, you could try to extract your firmware , repair it then load it back on your player.
It could also be a fault in the radio chip on you board if so I do not think it can be fixed unless you can get a technician to replace it.
  #92 (permalink)
Old 28th Jul 2006, 11:13 am
Hey boyz........
I'm havin few problems wit my player first of all its dead hence it want start.............
i tried the recover guide posted by xxxx
https://www.mympxplayer.com/viewtopic.php?t=567
and got half way thru and got this msg.........
"the file 'AdfuUd.sys' on USB mass storage device is needed"
can anyone help please.....
  #93 (permalink)
Old 28th Jul 2006, 12:07 pm
thank you for the guide
it functions perfect
first the firmware of the link dont serve but I upgrade before with a dump.bin of my firmware and PERFECT ALLL.............
THANK YOU
ps
excuseme for my english
  #94 (permalink)
Old 31st Jul 2006, 6:16 am
cfbp, Glad you got your player going again, well done.
  #95 (permalink)
Old 31st Jul 2006, 6:17 am
bmmsid, If you have MP3 Player Utilities installed there is a copy of th ADFU driver in RDisk Update\Driver folder.
  #96 (permalink)
Old 3rd Aug 2006, 7:52 am
Hi – Just got mine Mp3 4g from Wilson, it had ver 3.5.35 I wanted to update to ver 3.5.37.
The first one I tried did not update. The next one I downloaded – updated – but then I got A BLUE SCREEN I do have access to the chip (my files are still there) I did back up before I started.
When I try to use the upgrade tool - to upload the old firm ware, it says or " Device switching has failed, Reconnect device" or "Device not detected"
I just want to make sure before I start that, I have to go through the whole process of opening it up and touching the chip etc.
Please help.
  #97 (permalink)
Old 3rd Aug 2006, 9:44 am
markshmid1 : see all the recovery guide in the first page of this forum. is sure that you can recovery it ...
good luck
  #98 (permalink)
Old 3rd Aug 2006, 10:08 am
The question is do I have to open the gizmo up and short the chip to restart it? Or if i can go on to next step?
  #99 (permalink)
Old 3rd Aug 2006, 3:34 pm
Need Help!
I followed the steps of the recovery, all I get now is that sometimes Windows does not recognize the USB port (in the device manger it says “unknown device”) and in the firmware updater it says “device not detected”. I even formatted the drive and it did not help!
After rebooting the computer in the device manger it said “USB mass storage device” and when I ran the firmware updater it said “ Device switching failed, please reconnect device”
What do I do?
Help Needed.
  #100 (permalink)
Old 3rd Aug 2006, 8:06 pm
After playing with the gizmo some more: I see that somehow there are two drives on the gizmo one is: 3.99GB and one is: 1M.
1 mp3 players were detected, 1 removable disks, 0 ADFU devices
Is it possible that this is the reason I am having trouble?
