DEAD PLAYER RECOVERY GUIDE
  #1071 (permalink)
Old 28th Mar 2010, 12:59 am
Default Can't find the right firmware
Hi fellas...
I have a Chinese Sony MP4 player (the picture is attached)
Its a SUNPLUS MP3052A-HL171 M175Q030731
The problem is that I'm unable to find the right firmware for it...
Please help Click the image to open in full size.
  #1072 (permalink)
Old 28th Mar 2010, 1:56 am
evilpro
Can you create a seperate post instead?
In the subject, put the firmware information. This will help with the searches and if people find a compatible firmware, will post a reply to you.
  #1073 (permalink)
Old 28th Mar 2010, 2:21 am
Thanks a lot for Ur suggestion, Sir...
  #1074 (permalink)
Old 30th Mar 2010, 8:07 am
DHK DHK is offline
Got the drivers for the usb device installed but windows isn't picking it up in my computer or disk management? how can i format?
  #1075 (permalink)
Old 7th Apr 2010, 12:31 am
Very often the USB leads supplied are faulty. I had a ipod lead and a mini USB lead supplied for 2 players both faulty. Replace with better quality ones cured player/upload problems etc.
ian
  #1076 (permalink)
Old 14th Apr 2010, 4:40 pm
I have an ms 408 gloss:
Chip: hynix KOR HY27UU08AG5A TPCB 821F
i can not find firmware
  #1077 (permalink)
Old 15th Apr 2010, 4:24 am
Hi kocko
I guess the HY27UU08AG5 is a 2GB Hynix flash chip. You will need a lot more information to find the firmware. Like numbers of controller chip and display device. Also if you could post the picture of your player so that people with a similar one can see... and share their firmware with you.
hope this will help........
  #1078 (permalink)
Old 15th Apr 2010, 3:45 pm
MS 408 gloss
It is HY27UU08AG5 TPCB 821F a 2GB Hynix flash chip.
display tipe: 1.66" tft
display resolution 160x128
can this help,to find firmware?
  #1079 (permalink)
Old 15th Apr 2010, 9:21 pm
kocko ... just lift the battery and you would see another chip (second largest on board), this would be the micro-controller (master). Also on the side of the LCD would be some numbers written, post these two part numbers and see we could locate a suitable firmware for your device.
yes ... the largest chip is the flash memory and in your case it is a 2GB ... How much was stated on your player ??
  #1080 (permalink)
Old 16th Apr 2010, 2:29 pm
I lifted the battery,but there was nothing there.i found master chip on anoter side.
ALI dri
m5661e b1
d737 tg05
x719124000ga
but there are no numbers writen on the side of the lcd
