DEAD PLAYER RECOVERY GUIDE
  #151 (permalink)
Old 18th Sep 2006, 3:47 pm
I tried waterlily but I couldn't make it work
But I can live with it :P As long as the gizmo works, it's a minor defect
  #152 (permalink)
Old 22nd Sep 2006, 1:44 pm
hi,
my comp doesnt detect my mp4 player( like same as on the guide)
i make a connection between the pins on one side of the chip but i didnt able to reset it. it just restart by doing it.
so how can i do it, i'm sure i can make next steps but i have to do this first
anyone help?
  #153 (permalink)
Old 22nd Sep 2006, 5:59 pm
BrandonWalsh, I have found that the chip can be reset on either side and even crossed from one side to the other.
  #154 (permalink)
Old 23rd Sep 2006, 1:48 am
tadad1 and all other people, i have the same problem with same nanolike crapPod player, can you tell me specificly how did you work on dead player, how should i connect these pins inside a player. pictures and previous description didnt help me, i tried but no " device detected" message only flashing screen, hourglass on blue background. Thanks for help
  #155 (permalink)
Old 24th Sep 2006, 8:08 am
ardo101, I can not explain it any clearer than in the guide. If your player has been detected by windows as an ADFU Device before it may load the driver without any notification so after shorting the chip try the upgrade tool to see if it detects your player.
You could also try shorting your chip on either left or right side or accross the chip. I have found it resets almost anywhere. Make sure your metalic object is not aluminium as it may not conduct as well.
  #156 (permalink)
Old 24th Sep 2006, 12:55 pm
PLEASE I NEED A FIRMWARE FOR A MARKVISION OF 512 MB, PLEASE SEN ME TO JOHANFER_12@HOTMAIL.COM, I TRIED 10 FIRMWARES AND NOT WORK ONLY SHOWS A LIGHT PLEASE HELP ME,
  #157 (permalink)
Old 24th Sep 2006, 4:30 pm
JOHANFER12, It is impossible to tell you which firmware will work with your player there are just to many variations. You may need to try 50 - 100 to find the right one.
  #158 (permalink)
Old 24th Sep 2006, 6:20 pm
I BELIEVE THAT WITH THE ORIGINAL IS SUFFICIENT, PLEASE IF ANYONE HAVE IT PLEASE SEND IT TO JOHANFER_12@HOTMAIL.COM. VERY THANKS
  #159 (permalink)
Old 25th Sep 2006, 10:22 am
ok i'll try it once more, that pins staff, but question about firmware, before reinstall or putting new firmware what i have to do to get/backup recent software. And where i could get about 50-100 different soft version, i have seen in this forum only three one (...35/ ...37)
  #160 (permalink)
Old 27th Sep 2006, 5:26 am
Hello guys! I'm happy! I've recovered my Chipod! I've buy another identical player because all firmwares of the download section are not for my player! I've extracted firmware from new player and flashed into the old, and now all work perfectly!!!
Here is my player:
I've uploaded the firmware for helping other people with my same player. Why after upload i don't see it in the "uploaded by members" section?
Bye bye all
