DEAD PLAYER RECOVERY GUIDE
  #231 (permalink)
Old 19th Oct 2006, 5:11 pm
deadnano,
To the best of my knowledge there are no 3.6** version firmware. If it had a 6 it was possibly 3.2.16.
If you start a new post with some images of your player, some links to where you purchased it someone may have bought the same player and could upload the firmware for you. Also try contacting brohauns and see if they will send you a copy of the firmware.
  #232 (permalink)
Old 20th Oct 2006, 9:12 am
Hi i followed the guide and got to the point where my player was recognised as drive F then i flashed it several times with various firmwares like it said but now everytime i try to flash it i get the message now is recovery state " " ". and it is no longer recocognising it as drive F but i do here the connection noise when i plug it in
my player is http://www.uxcell.com/uxcell/retail/...v0pur1024mp002
thanks
  #233 (permalink)
Old 20th Oct 2006, 10:35 am
nice it took me a whole day but it is working now, this site is great i now know how to change the files to display my own pics and mod the firmware this site is so cool thank you much
  #234 (permalink)
Old 20th Oct 2006, 1:53 pm
broose, If your player is in Recovery State then you need to use a full version firmware first then you can start loading dump files.
  #235 (permalink)
Old 20th Oct 2006, 1:55 pm
deadnano, You will have to change your user name now
  #236 (permalink)
Old 20th Oct 2006, 2:01 pm
i guess dead nano isnt good any more huh, well im working on some cool theams so i will upload monday
  #237 (permalink)
Old 20th Oct 2006, 2:10 pm
deadnano, Look forward to seeing them.
  #238 (permalink)
Old 21st Oct 2006, 1:36 am
Yeah i did that tadad1 but when i relaunch the firmware update software i get the same recovery state message. i use the full firmware then i turn it of for 30 seconds then turn it back on , i here the noise windows makes when it has found a device, then i relaunch the recovery tool and i get the same message about being in recovery state.
cheers
  #239 (permalink)
Old 21st Oct 2006, 3:23 am
broose, This has only happened to me if the full firmware is completely unsuitable for the player. Using a different full versiopn firmware should get you to the next step.
  #240 (permalink)
Old 21st Oct 2006, 6:44 am
i used the full firmware the first few times and everything went ok, then it just started doing the recovery state thing all the time.i will try again, what full version do you think i should use?
thanks
