DEAD PLAYER RECOVERY GUIDE
  #271 (permalink)
Old 28th Oct 2006, 4:59 am
mrbeny81,
Can you still load firmware to your player? The firmware in the upload tool clears every time you load a new firmware.
Do you remember which firmware you used when your player worked and showed 1GB?
  #272 (permalink)
Old 28th Oct 2006, 5:32 am
yes im all the time try but no resultat. When i instal the firmware (on adfu - is posible now) and when is don i see blue scree on player and in explorer i see just partition
what can i do??????
  #273 (permalink)
Old 28th Oct 2006, 8:55 am
There must be some misunderstanding!
With my previous mail I wanted to say:
I've tried to replace my firmware, did something wrong and my player died. But useing the "dead player recovery guide" and http://mdl5.mydown.com/driver/200609...v80_fw9043.zip
I was able to repair my player, and after that edit it with s1fwx!
SO there is a way edit 9.0.43, but I must say it's not so easy like wih older firmwares.
BYe:
heavy
  #274 (permalink)
Old 28th Oct 2006, 9:24 am
HELLO tadad1
Thank you You vrey hlep me
but now i have another problem
wish my mp4 i stup full f/w because
my mp4 show blue serccn
i stup 3 time full and now my
mp4 dont show screnn only
adfu all the time and i stup new full
f/w and all time is show me adfu
wat to do about situation?
tnx for u hlep :cry:
*my mp4 is fake "ipod"
ipod pic
ipo pic2
  #275 (permalink)
Old 28th Oct 2006, 10:29 am
Start from begining of recovery guide and have fun :P
  #276 (permalink)
Old 28th Oct 2006, 10:44 am
tnx i try
BUT You CAN give me
"Url"? TO
begining of recovery guide :?:
  #277 (permalink)
Old 28th Oct 2006, 10:46 pm
hey peaple
i need help
i tried to upgrade3 the firmware of my mpx player and accidently put in the wrong firmware.
Now my player is dead but my computer is able to read it as an unknown usb device.
If i try to install the 'AdfuUpdate.inf' from the windows folder then a message appears 'the specified location does not contain information for your hardware'.And if i put the installation settings on automatic then the computer installs some drivers in the the player, then the the computer still reads the player as an unknown device but when i check its properties
then the device type shows that its a 'Universal Serial Bus controllers'
and the drivers details shows that the 'no driver files are required or have been loaded for this device'.
In short i am not able to install the 'AdfuUpdate.inf' .
ps-my mpx player is hacked to show 4gb and i am not able o remove the hack.
Please help
  #278 (permalink)
Old 28th Oct 2006, 11:43 pm
sratra, Try a different usb port, if possible one you have not used the player on before or one that you have used some other type of hardware.
Sometimes you need to short the chip quite a few times before the adfu device is read. Try shorting it in different places as well left side right side and even side to side across the chip.
As soon as you have it in recovery mode load a full version firmware then format the player and the hack will be gone.
  #279 (permalink)
Old 29th Oct 2006, 2:00 am
thank you tadad1. I was recovery my player by your guide, thank you very murch :wink:
  #280 (permalink)
Old 29th Oct 2006, 2:25 am
xuanchung, Thats great mate, I love it when another player gets recovered. Well done.
