DEAD PLAYER RECOVERY GUIDE
  #311 (permalink)
Old 2nd Nov 2006, 4:40 am
tadad1
do you mean the full firmware?
  #312 (permalink)
Old 2nd Nov 2006, 4:42 am
tadad1
i had got the full firmware from;
http://www.mympxplayer.com/dload.php...6364da93f003b1
and the dump from;http://www.mympxplayer.com/dload.php...le&file_id=186
  #313 (permalink)
Old 2nd Nov 2006, 5:18 am
sratra, Ok well I tested the dump and it is ok so it is most likely just not compatible with your player. I can only suggest that you keep trying the other dump files. If you have no luck try a different full version then try the dumps again.
  #314 (permalink)
Old 2nd Nov 2006, 10:09 am
Please Help! What I need to do to upload a full firmware on my Sigmatel based mp4 player zc-45 (1.5'' screen, 1GB, FM,...) U can send help to my e-mail too activated@inbox.lv
Please, please help.... ;(
  #315 (permalink)
Old 2nd Nov 2006, 1:39 pm
What can I do with .bin files? How I can upload them to my player? Do I need any software to do that? PLZ HELP!!!!
  #316 (permalink)
Old 2nd Nov 2006, 2:16 pm
DO NOT PANIC and read guides man
Good man :wink:
  #317 (permalink)
Old 2nd Nov 2006, 2:17 pm
ActivatedTM,
Sigmatel chipset firmware is very different to Actions chipset firmware which you can not load to your player.
Sigmatel firmware generally comes with it's own install. We only have a couple of Sigmatel firmware on site.
http://www.mympxplayer.org/sigmatel-firmware-dc36.html
  #318 (permalink)
Old 4th Nov 2006, 2:38 am
tadad1,
I think that Sigmatel firmware 2.600.600 is the right one for my player,but when I try to upload it, then at the end error message appears: "update verification failed" What does it mean and what can I do?
  #319 (permalink)
Old 4th Nov 2006, 3:00 am
ActivatedTM, I have never owned a Sigmatel player so sorry I am not familiar with the upgrade process.
Have you checked out the Sigmatel forum at s1mp3.org
http://forum.s1mp3.org/viewforum.php...9ccad2e5aea5db
  #320 (permalink)
Old 5th Nov 2006, 1:15 pm
How do I find out what chipset it is using? This is the ebay link for the mp4/mp3 player I purchased: http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=016.
Please tell me how I can fix it as I have only had this player for a short amount of time. Thank you.
