DEAD PLAYER RECOVERY GUIDE
  #351 (permalink)
Old 2nd Dec 2006, 7:52 pm
HotCrisis16, If the player is still showing the hourglass after shorting then the player is not going into recovery mode.
You may need to disconnect the battery and then cross the pins and keep them crossed while connecting your player to USB. If possible use a new usb port to connect, preferably one you have not used the player on before.
  #352 (permalink)
Old 2nd Dec 2006, 8:14 pm
Ok I did that and used a diffrent computer at the same time and still nothing.
  #353 (permalink)
Old 2nd Dec 2006, 9:01 pm
HotCrisis16, Then the player may be unrecoverable. Unless you can get it into ADFU mode there is no way you will be able to start the recovery process.
  #354 (permalink)
Old 3rd Dec 2006, 4:35 am
KKS KKS is offline
I don't know what a player i have
here is a photo
I Upgrade player this firmware, disconnect player and run MP3 Upgrade Tool again and see this massage
What i should do to back my player to life?
PS. I have backup my original firmware (dump.bin) but i must upgrade this dump.bin file with some original files , but i don't know what files i should upgrade
Help me please!!!
  #355 (permalink)
Old 3rd Dec 2006, 4:54 am
KKS, Try placing a small piece of card on top of your memory chip and press down gently on it while you try to load your backup dump.bin.
If you extracted your backup dump with s1fwx and then ran the repair.bat to repair it then your dump should be ok. If you did not repair it after extraction then place it in the s1fwx folder and run the repair.bat, then try the above.
  #356 (permalink)
Old 3rd Dec 2006, 5:58 am
KKS KKS is offline
is that all I need to do, to get "It is recover state, and select the firmware file for recovering please"of the message? - I have already got it.
I have a dump.bin file on "s1fwx" directory.... run a repair.bat and have
Code:
s1fwx v3.1 - copyright (c)2005-2006 wiRe (http://www.s1mp3.de/)
repair dumped firmware file...
backup file to 'dump.bi$'...
try to repair firmware...
error: repairing file failed
message
  #357 (permalink)
Old 3rd Dec 2006, 6:19 am
KKS, could you zip and upload your firmware dump to www.uploaded.to and then leave me a link so I can look at it.
  #358 (permalink)
Old 3rd Dec 2006, 10:14 am
KKS KKS is offline
Here http://uploaded.to/?id=5d58d8
  #359 (permalink)
Old 3rd Dec 2006, 12:27 pm
KKS, Your dump is already repaired and seems to be fine. If your player is in recovery mode then you will need to load a full version firmware to it. Once you find a full version that brings your player out of recovery mode and detected as a removable device then load your dump to your player.
  #360 (permalink)
Old 4th Dec 2006, 6:38 am
Hi everyone , i have tried this technik and it shows me ADFU device is detected but when i install driver for this component selecting "ADFUupdate" there is nothing whatever i tried to touch to mp3 player tool to upgrade but it says me that no device are detected ...
please help me restore my mp4 it is a IPOD nano like
give you references SAMSUNG619 K9K8G08U8A and ATJ2085W if someone can help it will be helpful please @ bilal1244@hotmail.fr before yesterday the screen showed sand glass but today nothing i have no idea of what to do it has worked only 5 days , bought it in summer and tidy in my cupboard
i hope you will help me bilal1244@hotmail.fr
