DEAD PLAYER RECOVERY GUIDE
  #31 (permalink)
Old 28th Jun 2006, 5:57 am
vinod,
Good to hear you got your player working again and thankyou for letting us know.
If you get a chance please upload your firmware to the Downloads>Uploads by Members section. The more versions we have for download the better.
Cheers
  #32 (permalink)
Old 28th Jun 2006, 7:42 am
Hi all! I m in a big trouble. I bought an mp4 player
2 weeks ago(the same that on the pictures at dead player recovery). One day the battery went dead. I connect it to the computer to charge. After a few hours i saw it has been turned off. After this I can't swith it on.
I try "dead player recovery but it isnt worked my computer isnt recognize it. PLS somebody help.
Sorry but i cant write correctly in english.
  #33 (permalink)
Old 28th Jun 2006, 8:29 am
delerium69, Sorry to hear about your player it sounds more like a faulty player than a firmware issue. It could be a faulty USB cord and no charge is getting to the battery or the battery itself may be the problem. I suggest you contact your seller as it may still be under warrenty.
  #34 (permalink)
Old 28th Jun 2006, 10:06 am
Thanks for ur answer. But I talked to the seller he dont know wht is the problem. So I sucked...
  #35 (permalink)
Old 30th Jun 2006, 3:08 am
delerium69
Please create a new post for your question. We can help more from there.
I would suggest try a different USB cable, as well as a wall charger too to try to eliminate the possible problems.......
Wait to hear from you then.
  #36 (permalink)
Old 30th Jun 2006, 7:08 am
thx 4 this info
i think everyone like this guide
  #37 (permalink)
Old 3rd Jul 2006, 1:00 pm
I have tried the above method but I am having a total different situation here. I get this and says that this device is unknown when i attach the player through the usb.
http://img477.imageshack.us/img477/3518/018rg.jpg
I try to install the driver AdfuUpdate found in C:\Windows and I get this
http://img477.imageshack.us/img477/5954/029yc.jpg
Any other ideas of how can this be resolved ? t.y.
nevermind am throwing it away lol. thanks for the guide it looks great
EDIT: I was just about to throw out the player. I've tried to connect the pins again and the light came on . I've used one of the full firmwares here and it worked . So, if you are in the same boat as I am, try the guide again
EDITx2: btw you are a genius and we love your guide
  #38 (permalink)
Old 5th Jul 2006, 8:27 am
ann ann is offline
This is an excellent guide. However, I am having trouble finding a backup dump.bin file to restore my player. I have the exact replica of the player you have in your guide. I have downloaded several firmware files, but most get an invalid firmware file message in the mp3 update tool. Please help!
  #39 (permalink)
Old 5th Jul 2006, 3:54 pm
Thank you so much whit your guide i could bring back to life mi dead player
thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you
if i made some mistakes is because i'm panamenian and i'm still learning english
  #40 (permalink)
Old 5th Jul 2006, 4:35 pm
Ciberhaguen, WOOOOO, you are one happy Panamanian and your English is great. I am glad you got your player going again
