DEAD PLAYER RECOVERY GUIDE
  #411 (permalink)
Old 13th Dec 2006, 10:35 pm
jon jon is offline
Hey i need help: i need the firmware for this mp4
Board: mp-693c-sl key v1.2
memory: 637
k9k4g08u0a pcbo
its has 4 gb nano like
PLEASE HELP ME GUYS!!!!!!!!!!!!!!!!
HOW CAN I USE THE 7Z FILES???
PLEASE HELP ME AND GIVE ME A LOT OF OPTIONS TO TRY....PLEASE!!!!!
Crying or Very sad
  #412 (permalink)
Old 13th Dec 2006, 11:34 pm
jon, 7z files are like zip files but with greater compression, you need to install 7zip ir Winrar to extract them. you can download the latest freeware version of 7zip here: http://www.7-zip.org/
  #413 (permalink)
Old 14th Dec 2006, 5:17 am
Tadat your the expert and i would like to know if i m correct to put a Firmware correctly?
1-I have maked a Short circuit
2-I have open RdiskUpdate.exe
3-I find my Firmware and i select him
4-I clic on begin upgrade
That it?
  #414 (permalink)
Old 14th Dec 2006, 5:35 am
lefrosth,
You only need to short the chip if your player is not detected by Windows or the Update Tool. If your player is detected then you can just use RDiskUpdate as you have discribed in steps 2,3&4.
If your player is not detected then you use Step 1 until your player is recognised by Windows as an ADFU Device then you can use steps 2,3&4 but you must install a full version firmware if your player is in ADFU Mode. If you can not get it detected as an ADFU device then it will not work. If you are having problems try connecting to a different USB port and short the chip in different places, I found I had the most success shorting the pins from side to side accross the chip.
Once you load the full version firmware then you can try some dump files.
  #415 (permalink)
Old 14th Dec 2006, 9:49 am
Yes, when i connect my mp4 . Windows post this message.
After i find my Firmware.
After i extract the Firmware in ''recover''
After i find my Firmware i have extract
5min and 10min later ... nothing
Do you thing it is a Bad Firmware?
  #416 (permalink)
Old 14th Dec 2006, 10:57 am
I'm having the same problem as lefrosh dont know why?
  #417 (permalink)
Old 14th Dec 2006, 12:48 pm
i loaded up the firmware but i still get a blue blackish screen..
  #418 (permalink)
Old 14th Dec 2006, 1:03 pm
Ya is very stupid, i m sure tadad1.He can to fix this probleme.I think it is a stupid probleme...
  #419 (permalink)
Old 14th Dec 2006, 1:59 pm
lefrosth, How long ago did you buy your player, because The 3.2.16 firmware you are using is dated 19-06-2005 and I doubt it will even load onto a new player.
What version was your original firmware?
You should not put them in the recover folder either. This folder is created by the RDiskUpdate.exe when the firmware is loaded and it will rename the firmware $actsdk$.fw and place it in the recover folder. I would even advise that you delete the recover folder after trying a firmware as the update utility can sometimes get hung and keep trying the same firmware over and over.
I suggest you find a full version firmware that matches your players original firmware version.
  #420 (permalink)
Old 14th Dec 2006, 3:32 pm
jon jon is offline
HEY GUYS THANKS NOW I KNOW WHAT ARE 7Z FILES...
BUT I HAVE A ANOTHER PROBLEM: I START TO UPDATE MY MP4 WITHOUT MAKE A BACK UP OF THE ORIGINAL FIRMWARE (NOW THE SCREEN IS DARK BLUE). MY TROUBLE IS KNOW THE RIGHT FIRMWARE FOR MY MP4.
THE SPECIFICATIONS OF THE MP4 ARE THESE:
MEMORY: samsung 637
K9k4G08U0A
pcbo
BOARD: MP-693C-SL KEY V1.2 KNIFE 051111
4 GB
COLOR:BLACK LIKE IPOD NANO
PLEASE AGAIN!!! GIVE MY THE RIGHT FIRMWARE FOR MY MP4!!!
