DEAD PLAYER RECOVERY GUIDE
  #41 (permalink)
Old 5th Jul 2006, 4:38 pm
ann, Thank you for your note I have sent you a reply.
  #42 (permalink)
Old 6th Jul 2006, 1:59 am
I have installed a firmware 3.2.16 and I'm happy that it is detected as a removable disk like before.Things are getting normal but the display screen IS STILL BLACK.NO DISPLAY AT ALL.I'm so much worried abt this problem...Help me.. .NOW WHAT SUD I DO?
Regards
Sachit
sachitmaskey@gmail.com
  #43 (permalink)
Old 6th Jul 2006, 2:27 am
sachitmaskey,
You just need to find the right firmware to restore your player.
What was your original firmware version?
What did the menus look like?
  #44 (permalink)
Old 6th Jul 2006, 9:00 pm
sachitmaskey, it took my player a good minute to settle in the firmware and have the screen show the menus and screen selection and all that. So, just keep it open and everything will appear. At least thats what I did.
That should work out for you.
  #45 (permalink)
Old 9th Jul 2006, 7:46 am
sorry my friend I already did your guide, but when recovery process came up warning that said "Read Or Write information failed! Please exit the program and check if device connecting!"
what shoul I do ???
plzz help me
  #46 (permalink)
Old 9th Jul 2006, 8:10 am
what shoul I do ???
plzz help me
  #47 (permalink)
Old 9th Jul 2006, 11:53 am
You need to use one of the full firmwares we have in out Download section. And, short the pins only once when the device is detected by windows and after than, open the update program and use one of the full firmwares to bring it back to life.
  #48 (permalink)
Old 10th Jul 2006, 5:07 am
wexku, You may have to repeat the process more than once. You may also need to try one of the other full version firmware and format your player.
  #49 (permalink)
Old 10th Jul 2006, 5:23 am
Hi all!! I have an IPod nano clone 2Gb 1.5". My old firmware SC85051B ACT_V3.5.35 2006/03/17. I Update with a wrong firmware and now my player dead. I use this guide and arrive to "Now is recover state, and select the firmware file for recovering please!". When i try to put a new firmware with the "MP3 Player Upgrade tool" and push "Recover Firmware"
appear the error: " Unknown flash type!" and the display turn on blue screan! :cry: If i turn off the player and i turn on the display is black.
I try with all fimware that there are in this forum.
Please help!
Sorry for my english ops:
  #50 (permalink)
Old 10th Jul 2006, 5:31 am
bianchidavide, You must use one of the firmware from the full firmware download section first. Then you can try the dump files from the Medium Color Screen section. If that fails you may need to format your player between upgrades.
