DEAD PLAYER RECOVERY GUIDE
  #501 (permalink)
Old 18th Jan 2007, 5:12 pm
you may try and open it and see it the usd connector pins inside if it is broken(happend to my old one) this may happen when the pin is a bit out of the place and when you pluge it use cord in and resulting in pushing the pins in or bending it. if not that problem look into either if the batteryis connected correctly, or is it a defective one. look for is anything looks like burned out, make sure you didn't staticed it due to the winter(you get more statics during winter some how) another thing i found out, all the people with the restarting problem, it is not the faulty machine, it is the statics also, try taking a sweater off and have the mp3 player touching the sweater, it will restart. Hope you get yours working!
  #502 (permalink)
Old 21st Jan 2007, 1:13 pm
i want to thank u very mush u really help me , i have make all steps but it just stop in explorer sign . i have coverd my firmware with Version 3.2.16 and it just show the explorer sign and when i reconnect it to format i can not find it in windows as driver it is still aduf not usb device so i can not foramt it by using windows or even by using mp3 formating tools what i shall do my player is white and called gigamax MP-693C-SL MAIN V1.3 2005.12.14 plz i need help
  #503 (permalink)
Old 21st Jan 2007, 1:25 pm
make sure the file systme is in fat, but if it is in fat 32, windows can still formate it- thats a note
  #504 (permalink)
Old 21st Jan 2007, 9:55 pm
Default firmware
Please help!!! I need firmware for my dead mp4
FW: B806K8X_v2.0
Core: 9.0.50
  #505 (permalink)
Old 21st Jan 2007, 10:33 pm
more detail please???
  #506 (permalink)
Old 21st Jan 2007, 10:43 pm
heres the specs
1.8 inch Large, 65,000 Pixels Full Color TFT LCD Display
FW: B806K8X_v2.0
Core: 9.0.50
  #507 (permalink)
Old 21st Jan 2007, 11:10 pm
macking , there are some v9.0.xx firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
If these do not work, then there is nothing much you can do. As the firmware extractor currently does not support any versions higher than v9.0.43.
  #508 (permalink)
Old 22nd Jan 2007, 3:57 am
@lattesurf
i try the version 9.0.43 and 9.0.48 still don't work with my player, my next step is to copy the firmware of my friend's mp4 player coz we have the same model, gladly i extract his firmware using s1fwx , still the result is just a white blank screen
Can anyone help me on what to do to recover my mp4?
  #509 (permalink)
Old 22nd Jan 2007, 4:00 am
macking , two players may look exactly the same on the outside, even with same interface and screen images. But the firmware used maybe totally different from each other.
  #510 (permalink)
Old 22nd Jan 2007, 4:22 am
macking, If your friends player is also using 9.0.50 then the dump will not be usable. s1fwx will not extract a complete backup of any versions above 9.0.43. A new firmware extraction tool is being written for these newer versions but may not be available for some time.
