DEAD PLAYER RECOVERY GUIDE
  #521 (permalink)
Old 24th Jan 2007, 6:04 pm
i really do not know what i have 2 do could any body help me what i shall do after the explore sign appear the windows did not detect the player as usb and iam not able to format it i covered it with 3.3.13 firmware plzzzzzzz i need help
  #522 (permalink)
Old 24th Jan 2007, 6:07 pm
bravehearted, Right click on 'My Computer' and select 'Properties'. Go to the 'Hardware' tab and click on the 'Driver Signing' button and select 'Ignore' and 'Make this action the system default' then OK. You should now be able to install the driver know.
  #523 (permalink)
Old 26th Jan 2007, 1:26 pm
Hello Tadad1,
This guide is very helpful and u take so much of time for all, Thanks from the bottem of my heart.
my player is dead and i connected to usb port and installed ADFU driver and it shows ur hardware is ready to use, but it does not show drive letter. i try to reset chip couple of times and it detects as ADFU device but does not show drive letter and when i try to update full firmware it says flash not detected , . i also uninstall the driver and shutdown my computer and after start i connected my player it automatically detects as adfu device and then its all same.
Please help he tadad1 to fix this problem
Thank you
  #524 (permalink)
Old 26th Jan 2007, 1:28 pm
Originally Posted by popat007";p=&quot View Post
Hello Tadad1,
Thank you
  #525 (permalink)
Old 26th Jan 2007, 2:14 pm
popat007, When your player is in ADFU mode it will not show in Explorer because windows will not recognise it as a removable device. Once you successfully install a full version firmware it will show in Explorer then you will be able to format the player.
If you are having problems loading a full firmware try MP3 Player Utilities 4.05 or 4.07.
  #526 (permalink)
Old 26th Jan 2007, 2:23 pm
when i run mp3 utilities 4.05 -->mp3 player upgrade tool, itsays Device not detected :cry:
  #527 (permalink)
Old 26th Jan 2007, 2:47 pm
popat007, Try connecting your player to a different USB port.
What version was your players original firmware?
  #528 (permalink)
Old 26th Jan 2007, 2:58 pm
I just now tried with 4.07 and it says "Read or write device information failed.please exit the program and check if device is connecting."
it was 3.5.37 and my chipset is ATJ2085H samsung 631.
i am trying from 2 days, i use all of my 3 usb ports
now what should i d? :roll:
  #529 (permalink)
Old 26th Jan 2007, 5:43 pm
popat007, What full version firmwares have you tried to load?
  #530 (permalink)
Old 26th Jan 2007, 5:57 pm
I tried to load 3.5.37v2.1b FM.fw and FM.fw from 3.5.35Full-.rar file
when i run FM.fw of 3.5.35Full.rar it says successfull retrived but do not show ADFU or any drive and when i try 3.5.37v2.1b itsaysno device detected. no sign .when i shot pins on booth side light came on to screen
but no ADFU or drive. i dont understand whats happening. when i disconnect usb then also light remains and i connected once in usb of computer, nothing buzz or dectected.
