DEAD PLAYER RECOVERY GUIDE
  #551 (permalink)
Old 29th Jan 2007, 8:01 am
I have Nano ZC-45 1gb 1.8".So i try to do something with firmware and now i have dark blue light on the screen.I can use like removable disk but not like mp4 player.The firmware what i had befor was version:3.5.37. Can somebody tell me what i should do to make alive my mp4 player. :cry:
  #552 (permalink)
Old 29th Jan 2007, 4:00 pm
please i need help my pc recognize "USB DEVICE"
But when install drivers ADFU show me this popup:
Sorry for my spanglish jaja
  #553 (permalink)
Old 30th Jan 2007, 12:30 am
Hai tadad1 .I have done all the things and now i was stucked. I had recovered the player and they said that check the device is working or not... Then i removed the player and turn off and on. the computer is not detecting it... :cry: Then how to format without the computer recognise it? I have only the screen is flashing..... Please help me.... :cry: :cry:
  #554 (permalink)
Old 2nd Feb 2007, 8:27 am
:twisted: Hi to all of you. I've got the same problem: a dead mpx player. I've followed the precious instruction at the top of this forum but I think i'm still far from the solution. When i try to save a new firmware in my dead mpx (I use the latest version of the tool - 4.07) the process stops after few seconds and the program doesn't react anymore. I've tried with many complete firmware versions but i'm still here! Please help me!
  #555 (permalink)
Old 5th Feb 2007, 8:04 am
Dude you are amazing!! Super thx.
Fixed - So I followed the steps in detail. The only thing I would add to this for users with the ATJ2091H chip is the following link to the only firmware that I would will work:
http://www.mympxplayer.org/full-vers...lcd-df441.html
This latest chip set is for the 4GB device. Since the new firmware and reformat (FAT32) it works fine now.
Yes, I owe you a beer!
PBXJEDI
  #556 (permalink)
Old 5th Feb 2007, 12:08 pm
bobo1701 , try to use other versions of MP3 Utilities. Uninstall the current v4.07 and install other versions like 3.68, 4.00, etc.
  #557 (permalink)
Old 12th Feb 2007, 5:23 am
help meeeeeeee! I'M ARRIVED AT THE BLUE SCREEN BUT I CAN'T FIND A GOOD FIRMWARE! MY POD BOARD IS APPLE-M V2!!!
  #558 (permalink)
Old 12th Feb 2007, 5:23 pm
arh arh is offline
hey picnik try this one
http://www.mympxplayer.org/dload.php...ad&file_id=300
  #559 (permalink)
Old 14th Feb 2007, 7:46 am
i upgrade 9.50.00 firmware and i would like to know how to upload my backup dump.bin
thank's
  #560 (permalink)
Old 14th Feb 2007, 8:30 am
ngauss2005, If your player is using 9.0.50 firmware then your dump.bin will be no good. the firmware extraction tool s1fwx 3.1 will only work on version 9.0.43 and the 3.5.XX series firmware.
If your player is dead then all you can do is try some of the 9.0.XX sweries firmware in the Download>Firmware section, if they do not work for you then you may not be able to recover your player at the moment. A new firmware tool is being developed for these newer version firmware but it may be some time before it is released.
