DEAD PLAYER RECOVERY GUIDE
  #571 (permalink)
Old 17th Feb 2007, 3:14 am
i get the unknown flash error when i try to recovery
  #572 (permalink)
Old 17th Feb 2007, 4:51 pm
http://www.mympxplayer.org/image-asp271.html my need firmware for this MP4 my is 1GB
  #573 (permalink)
Old 18th Feb 2007, 10:55 pm
i have some problems,when im trying to update player to ADFU device,windows show the error
ADFU DEVICE HAS NOT PASSED WINDOWS LOGO TESTING TO VERIFY ITS COMPATIBILITY WITH WINDOWS XP
what to do?
  #574 (permalink)
Old 19th Feb 2007, 3:50 am
http://images.bite.lt/banga/files/cl...98c4662874.jpg
  #575 (permalink)
Old 19th Feb 2007, 8:29 am
woodzis , are you using an administrator account on your OS to perform the recovery?
You might need to do so, as user or guest accounts usually have driver/software installation restrictions.
  #576 (permalink)
Old 21st Feb 2007, 10:42 am
please i need full firmware for this firmware 9.0.43 2.0 inch lcd 512mb fake sony like the one from the contest
http://www.mympxplayer.org/image-asp...ac78fee695c8aa
  #577 (permalink)
Old 23rd Feb 2007, 7:00 am
Originally Posted by tadad1";p=&quot View Post
Dead Player Recovery Guide.
If you have tried to upgrade your player with the wrong firmware and you find it no longer turns on or is not recognised by your computer this guide may help you to restore your player. I suggest you read the whole guide before starting so that you understand what you are about to do and have everything you need. It is not fool proof there are no guarantees. If you have backed up your players firmware you have a much greater chance of succeeding if not then you will have to search for a firmware version that is compatible with your player. Look for versions that have the same features as yours and similar layouts and menu pictures. If you know the version number then look for that version. If you do not then get a few versions
First arrange a space near your PC where you can work. Make sure that your player is switched off and disconnected from your PC. You will need a fine screwdriver and a pair of metal tweezers. If you do not have any tweezers a second fine screwdriver or a bent paperclip even will do. I suggest that those without a firmware backup download a selection before starting.
Remove the 4 screws 2 on either side of your player.
Gently remove the stainless steel backing taking care not to lose the switch from the top of the player
Now connect your player to your PC and turn it on.
Using the tweezers or other metal item gently make a connection between the pins on one side of the chip. I have found this can be quite random you may also have to do it a few times.
If you are having problems resetting the player as an ADFU Device you can try this method. Place the tweezers across the chip conecting the first pin on both sides then drag the tweezers down all pins.
Your PC should now detect your player as a ADFU Server and install the drivers. If this happened you can skip the next section and continue after the red text.
If your player is detected as a USB device then you will have to follow the next steps in Red. Windows will try to install a driver for your USB device and fail. Right click on My Computer icon and select properties, then go to the Hardware tab and select device manger. Here you will find your USB Device.
Right click on the device and select properties. When the properties dialogue opens select update driver
Then select “Install from a specific location” and “Don’t search. I will choose a driver to install” then press next.
When the next window opens choose “Show All Devices” then next. In the next window select “Have Disk” then “Browse”. Now you will see you are looking for AdufUpdate.inf which you will find in the Windows Folder.
Once selected you will be asked to select the driver and it will be installed
Now the player is in a state where you can upload firmware so open the MP3 Upgrade Tool and you will be presented with this dialogue.
Note: If you have a backup of your firmware at this stage it is no good to you as it is not a complete firmware file and will give you an error message when you try to install it. You need to find a full version firmware. It may not have to be the same version as your original. My original was 3.5.35 and I used 3.5.37 to recover, you can download it here:
http://www.mympxplayer.com/dload.php...6364da93f003b1
UPDATE 28/06/06 Here is another firmware that also worked for me, it is a 3.5.35 version and it restored my test player with one flash instead of two. It is also fully themed. DOWNLOAD
Updated 06/07/06 "wolfport2001" has kindly uploaded a Full Version 3.2.16 HERE
Updated 27/6/06 Various FULL firmware versions are available from HERE
Once installed your player should show signs of life and you will be able to see it in explorer. It still will not be usable but is ready for the final step.
Turn the player off and then back on. Wait about 30 seconds till it boots now open the MP3 Upgrade Tool again. If it indicates that there is no device connected see if you can access your player through Explorer. If you can not you may need to format it with Windows. I have found that both FAT and FAT32 work on newer models but suggest you use FAT to avoid any problems. Once formatted the MP3 Upgrade Tool should have no problems. Now you can upload your backup dump.bin. Your player should now reboot and be fully recovered.
If you do not have a backup dump.bin you are going to have to try the firmware you downloaded until you find one that restores your player. Be aware that doing this could kill your player again in which case you need to start from the beginning and do the whole process again.
As I said at the start, this is not foolproof and there are no guarantees that the firmware I have used will recover your player but now you know the process and it is only a matter of finding the correct firmware. I believe that unless the player or its components are damaged that every player can be revived.
If you have a backup dump.bin please upload it to the firmware section along with a description of your players size, screen size, what feature it has, even a picture if possible, what ever information might help someone else identify it and recover their player.
If you recover your player you owe me a beer.
I have done all thing following step by step, but when i have had browsed to the windows\adfuudate.inf file it said that "the specified location does not contain the information about your hadware"
Can anyone help!
  #578 (permalink)
Old 23rd Feb 2007, 9:37 am
Default tell me fully dead player method
Hello every body I purchase 2GB FM fake ipod nano . When i upgrade my firmware my mp3 fully dead. my player is not connected to the computer the display. Pl tells me how can i recover my fully dead player and how can I get firmware ACT_V3.5.37 for chip ATJ2051H.Its borad not print company name. Only no. print 0644 29F2C08AAB WP .
My email - as_dhariwal@yahoo.com
pl tell me also how can i connected my fully dead for my pc.
  #579 (permalink)
Old 23rd Feb 2007, 9:50 am
When i follow DEAD PLAYER RECOVERY GUIDEi have some problems,when im trying to update player to ADFU device,windows show the error
ADFU DEVICE HAS NOT PASSED WINDOWS LOGO TESTING TO VERIFY ITS COMPATIBILITY WITH and pl tell me how can my pc show my fully dead player on my computer page as a removeble disk. my computer not dedecte my player.
  #580 (permalink)
Old 23rd Feb 2007, 5:24 pm
read dude
Go to the place where your disk are shown, then right mouse button - properities - Hardware - and in the middle- signatures of hardware - then set IGNORE.... and that s it and try again ADFU... You should find it Good luck
