DEAD PLAYER RECOVERY GUIDE
  #51 (permalink)
Old 10th Jul 2006, 6:39 am
tadad1, Thanks but i don't find the right firmware! And i don't view in "my computer" the device.
Help!!!
  #52 (permalink)
Old 11th Jul 2006, 4:40 am
i will try this tonight...
  #53 (permalink)
Old 11th Jul 2006, 12:10 pm
First THX for this !
I do all to the step were u say i schould open my mp3player upgrade tool. I use Firmware Upgrade Tool 4.19 and their dont came any message to me. So can u give me the link to the tool or say what i do wrong ?
THX :P
EDIT: OK i found it =) ! IT wörks !! GREAT THX
  #54 (permalink)
Old 11th Jul 2006, 4:08 pm
i need help i have a white MP4/mp3 player it was working untill i uploaded the wrong firmware i would not turn on so i read the dead mp3 players guide well it worked and i uloaded every firmware from this web site and it still dose not work but windows detets it and it and i can put files on it but it is black can some one please tell me what to do if you know please post thanks hunter yelton
  #55 (permalink)
Old 14th Jul 2006, 1:28 am
I "almost" owe you a beer:
This is my 1,8" 1GB MP3
Within 3 hours I owned it I was able to kill it (I was following the manual step by step to learn, antil the part: "Now it´s time to upgrade your player")
->F*** chineses, they have to tell in the manual that :"This proccess is absolutelly unecessary and will ruin your player"
Anyway, after 15 hours, I managed to make it work again, perfectlly, BUT:
-> I damaged it during the "operation": This model has the battery attached to the "back" part and four wires between the board and the back. Of course, one of them is now "loose", and I don´t really now where it fits.
Does anyone have a clue? Or maybe a link to a mp4-hardware site?
Thank you veeeeery much, If I may say so, you should add that we´ll usually need 2 files (one .fw and one .bin) to recover, both need to be from the same "number"model and are different for each player.
  #56 (permalink)
Old 14th Jul 2006, 2:07 am
Victor1980 ,
3 Hours to kill, not bad
Re Lose wire hope this helps
Re need 2 Firmware 1 .fw, 1 .bin. Not all full firmware are .fw some can be .bin. they also do not have to be the same number I have used a full 3.5.37 and a 3.5.35 dump together to recover a player.
Re Beer What is with ALMOST?
Glad you got your player up and running again.
  #57 (permalink)
Old 15th Jul 2006, 3:11 am
DUDE, You are the BEST!
Although you answered and found as impossible image of what I needed in 40 minutes, I ended up taking it to a technician. Since I don´t have the tools nor the skill to fix my "baby", guess this was the best choice.
Anyway, I upped the image on my other player, and demmanded him to see it! :lol: (he claimed he already knew how to fix it, but I trust no one anymore )
Thanks A LOT!
  #58 (permalink)
Old 15th Jul 2006, 3:40 am
Victor1980, DUDE that is an awesome BEER :shock:
CHEERS
  #59 (permalink)
Old 17th Jul 2006, 9:01 pm
Please help!
As many before me, I tried to upgrade and now get the flashing blue screen. Windows XP will not recognize the player, but there are no screws on this thing to open it up? Anyone with this type of player with no screws? MIne is a IPOD knock-off with apple logo on back 2GB
Any help would be apprecieted.
  #60 (permalink)
Old 17th Jul 2006, 9:07 pm
ddish, Unless you can open it there is not much you can do. Try to gently wedge the player open it may just have snap locks.
