DEAD PLAYER RECOVERY GUIDE
  #591 (permalink)
Old 9th Mar 2007, 6:11 pm
I have another problem when i try to install a firmware.Now,when i connect the ipod to my computer,it recognized as a adfu device,but i can't format it,can't do anything because it was write protected.What can i do?
  #592 (permalink)
Old 10th Mar 2007, 3:07 am
Cyen87,
if it is detected as adfu device, before formatting it, upload a full firmware using upgrade tools 4.0.X, you will notice that there will be a recover button instead of upgrade button. After you recover it , you may not need to format it, you my get your previous files in it. good luck.
  #593 (permalink)
Old 10th Mar 2007, 4:56 am
No no,that's not my mp4 problem. Now, it's memory is write-protected and I can't do anything.Can't format,can't use update tool to repair it.
Can you help me to remove the write-protected problem?
  #594 (permalink)
Old 10th Mar 2007, 11:07 am
Hi All. I need help with my MP3 player. Fake IPod Nano with IPod symbol in back from china:
Chip - ATJ2051H
And it has fake memory :/ that's why i have problem with copying my mp3s to player. I had put wrong firmware and it dead. I try to recovery follow GUIDE and i have right firmware but PLAYER STILL HAS BLUE LCD PLZ HELP ME BECAUSE I AM GOING TO CRAZY
  #595 (permalink)
Old 10th Mar 2007, 2:35 pm
hii
thanks alot for all this good work, i hope you can help me. i have this mp3 player looks exactly like the one in the guide. my computer recognize the usb however i can see it in the explorer are a removable drive. and when i run the utility tool. and click on begin download or recover (after choosing the fw) it starts but stoped in like 1/4 of the way.
plzzzzzzzz i neeed help
  #596 (permalink)
Old 11th Mar 2007, 4:30 pm
I first started with having the sand glass staying on the screen. I then tried the recovery procedure and installed a full version of one of the firmware I downloaded from this web. Instead of showing the sand glass, it showed a white screen. After reading this posting, I used the upgrade tool to upgraded the player using one of the .bin files on the CD that came with this thing. After that, I saw the drive shows up on the explore but the screen is completely black now. What shall I do? Seems like everything is okay now except the screen.
  #597 (permalink)
Old 11th Mar 2007, 5:35 pm
Update of what I have done so far after my last post...
I unpluged the player and connected it using another usb plug. This time, it said "unknown drive". I followed the recovery guide again and wouldn't able to install the drive back to the ADU drive. Also, when I chose the adfupdate.inf file it said it does not contain file for the drive or something like that. I tried to short it again and it didn't work for me. I'm done everything I could think of and played with it all day today. I'm gonna try it again tomorrow. Can anybody help me please? Please advice!!!
  #598 (permalink)
Old 13th Mar 2007, 10:11 am
Hello.
I have 2Gb nano clone with 1.5' display. Need FULL firmware to get it alive. Cant find for 1.5', most are for 1.8' displays.
  #599 (permalink)
Old 13th Mar 2007, 11:18 am
Tried almost all FULL flashes. If im trying to flash FULL FW, it shows "Downloading the restorable main program". If im trying to flash plain FW, it shows "r/w device information failed!..."
  #600 (permalink)
Old 13th Mar 2007, 11:36 pm
can't install driver, i driver in c:windows but it doesn't contain divice information, what to do, can u help me, i don't know my player name, at the front is written mp4 digital player and at the back side mp3 mp4 tested to comply with FCC standards for home or office user, can u identify what my mp4 is, i think it's fake, it came from china, i usually got mp4 and mp3 from china
some player capasity was lost when formating...
