17th Sep 2007, 7:02 am
wsdnbhd , i'll suggest that you repeat the shorting process again, and reinstall ADFU. See if this solves your problem.
spacegabry , the Samsung K9G8G08UOM is a 8Gigabit (1GigaByte) memory chip. So your player had been hacked to show 8GB instead.
Regarding the recovery, the firmware you have flashed in is not compatible, thus disabling your player again. You'll need to repeat the shorting of the pins again and try other v9.xx firmwares.
