DEAD PLAYER RECOVERY GUIDE
  #761 (permalink)
Old 17th Sep 2007, 11:16 pm
Sorry, but i have try all 9.x.x firmwares, and the player not work properly... Sigh...
  #762 (permalink)
Old 18th Sep 2007, 12:25 am
spacegabry , the problem lies because the current firmware extraction tool does not support versions above v9.0.43, so other users with working firmwares v9.0.48, v9.0.50, etc, are unable to extract their firmware for you to try.
If you have tried all the firmwares and none worked, i'll suggest you contact your seller for an exchange if it is still under warranty.
  #763 (permalink)
Old 18th Sep 2007, 5:40 am
Many thanks, I try to contact the vendor.
  #764 (permalink)
Old 18th Sep 2007, 5:45 am
try first firmware http://www.uxcell.com/public/mp3upda...INE-061218.rar when you install it player will show white screen but now try second firmware dump http://www.talpykla.com/files/2068/E...n%20second.rar
[flash width=600 height=290:56ca39393e]http://www.talpykla.com/files/2068/opr18C57.swf[/flash:56ca39393e]
ZIPY
  #765 (permalink)
Old 19th Sep 2007, 2:13 am
I tried to follow the great diagrams above but in my ignorance I may have damaged the board by trying ttweezers on the inside row of pins when using both sides did not appear to work. The screen is now completely black whereas before it was blue with the hour glass. Have I ruined it?
  #766 (permalink)
Old 19th Sep 2007, 3:28 am
See my post on page 51.
  #767 (permalink)
Old 19th Sep 2007, 4:53 am
Hi folks!!
I have my nano fake with the samsung chip k9g8g08u0m and ATJ2091H
My mp4 is dead. It only shows the wait image and nothing. I can make it to restore but when i update the firmware it never finish. Can you say me how much time is for full flash update??
regards
  #768 (permalink)
Old 19th Sep 2007, 10:31 am
My player is probaby, definitively died. Probabily, I have damaged the video chip (the display it does not work) on the multiple resets...
Many thanks for the assistance, lattesurf and lolita.
  #769 (permalink)
Old 20th Sep 2007, 12:22 am
Originally Posted by darrent";p=&quot View Post
This is a nice and detailed tutorial but a very important step missed.
In order to update the firmware "the player should be recognized by the computer" first. I mean your computer should allocate a drive letter to the player and you should see it under My Computer as a USB disk. Because it is not written clearly, I end up trying all the firmware versions for many hours, but it always stucked during flashing process with MP3 Player Utilities - Upgrade tool. It was just saying "downloading restorable main program". I realized that when I first saw the Update the firmware for your MP3/MP4 player tutorial written by admin.
Just a note...
I've been experiencing the same thing... "Downloading the restorable main program".. stucks there. Can anobody pls tell me what to do with this?
Remeber everything but forgive nothing. :!:
  #770 (permalink)
Old 21st Sep 2007, 4:32 am
WindBurn , try uninstalling the current version of MP3 Utilities, and install other versions instead. There are many versions available in the downloads section here http://www.mympxplayer.org/mp3-playe...ties-dc44.html
Some versions of MP3 Utilities are known to hang whilst trying to flash firmware into players for unknown reasons.
