DEAD PLAYER RECOVERY GUIDE
  #771 (permalink)
Old 21st Sep 2007, 10:07 am
Help me find this Firmware
  #772 (permalink)
Old 22nd Sep 2007, 1:14 am
Thank you for the reply. I did try this but perhaps you can clarify a couple of things for me.
1:- In my ignorance and because of another post found on this site I may have misinterpreted what I saw on the other post and tried to connect two pins on the same side of the chip, as when I did this the screen shut down and went black. Does this mean caput MP4 player?
2:- If point one does not rule out the possibility of restoring the drive, when trying to connect pins on either side of the chip does this mean for example Pin 1 and any of the other side pins and then pin2 and any other until hopefully success?
Thanks in advance Stefanaristo.
  #773 (permalink)
Old 22nd Sep 2007, 5:16 am
hi..ive posted on a different part of the forum tho now im going to try and go thru this guide...
the following is similar to my media player....
uxcell
its a 4GB one and the memory is fine, and hasn't been hacked...
i think wen i got it it had firmware 9.0.50...tho i wasnt aware of this....and tried to install a theme > myPOD theme
which is for 9.0.43...after installin it my media player went DEAD!
now wen i plug in the usb and the media player all i get is the sound windows has found new hardware will you like to install the drivers?
ne ideas one which to install?
if there is no chance of installin ne drivers for 9.0.43...im going to go thru this guide....
i was told about this firmware...viola firmware
and am going to try n get the pmp detected so i can upgrade the firmware to this Viola one....
does any one know if im going to hit ne problems or whether all this is possible?
  #774 (permalink)
Old 23rd Sep 2007, 7:35 am
I owe you a beer :9
  #775 (permalink)
Old 23rd Sep 2007, 1:55 pm
hey, i've tried everything you said but now i have a problem, since it is a trail and error thing, i have tried different firmwares, but now when i connect the usb in the pc and put the mp4 on i get a blue windows error screen about bad plug and play device and etc... any help???
  #776 (permalink)
Old 25th Sep 2007, 3:09 pm
hello my computer always recognizing the player as a usb device every time i do the resetting it resett but only recognizing the player as a usb device and if i try to install the AdfuUpdate it say that there is not the files it need
  #777 (permalink)
Old 25th Sep 2007, 6:34 pm
reactos , try these steps to modify the existing ADFU file:
Open Control Panel, and select System. Select the Hardware tab, and click on Device Manager. You should be able to see the player's USB device with the yellow exclamation mark. Right Click on it and select Properties. A new window should now appear.
Select the Details tab and in the drop down menu, select Device Instance Id.
Look for a line that begins with something like this:
USB\VID_10D6&PID_xxxx .....
Note down the 4 characters denoted by the xxxx. For my case, it is 1100, it might be same or different for you.
Now open the ADFUupdate.inf file with notepad. Look for the section beginning with [upgrade]. Add the following below it:
%USB\VID_10D6&PID_xxxx.DeviceDesc%=MDisk.install,U SB\VID_10D6&PID_xxxx
Note that you'll need to enter the 4 characters you located earlier on into this line. Replace the 4x with the number you recorded, there are 2 of these to replace.
Now look for the [Version] section, and locate this line:
;ClassGUID=1181f4a0-f284-11d2-9068-00609797ea5a}
The numbers maybe different from mine, but the steps are the same.
Remove the semi-colon " ; " from the beginning, and add an open bracket " { " at the beginning of the numbers. So you should edit it to something like this:
ClassGUID={1181f4a0-f284-11d2-9068-00609797ea5a}
Finally save the new ADFUupdate.inf file, and try installing your player using this newly edited file. See if this works.
  #778 (permalink)
Old 25th Sep 2007, 11:03 pm
a new window appear but no drop down menu with details and Device Instance Id is there some other way to get that information?
  #779 (permalink)
Old 25th Sep 2007, 11:44 pm
reactos , what OS are you currently using? There is definitely a Details tab when you Right Click and select Properties for the player USB device.
  #780 (permalink)
Old 26th Sep 2007, 1:45 am
i have windows xp home this is where i end up when i follow the instruction
http://mobilupplasning.to.md/uppdatering/egenskaper.JPG
