DEAD PLAYER RECOVERY GUIDE
  #811 (permalink)
Old 30th Oct 2007, 6:08 am
I have 4 identical chIpod shuffles which I purchased in China.
When a went to use the devices I kill two of them when I fully loaded the supposedly 4G player. It was then I figured out that I actually had 1G player. I followed the How to fix hacked chIpod instructions and fixed the remaining two machines to run as 1G player.
I then when about trying to recover the Dead chipods. Following the instructions and postings on this board, I have set the player into ADUF rescue mode. Now I need to load a full firmware version.
Going to http://www.exoticsa.com/2007/
I downloaded the 4.15 tool and used it to look at the firmware version on my working chipods: Bother were Wilson Co LTD version 9.1.51 firmware.
Then from the same site, I downloaded DIGIPOD SD-18N and uncompressed the firmware. At this time I added an .fw extension so that the MP3 utility can recognize the file.
When I open the file using the 4.15 MP3 utility the SD-18N.fw file is recognized as Wilson Co LTD version 9.1.51. When I hook my Player in ADUF mode in to the USB port the MP3 utility recognizes the player and said it is ready of upgrade. I tell it to upgrade the firmware and the utility
upgrades to player and indicates that the firmware installation was successful.
At this point the ADUF device disappears from the USB items listed under the Hardware Device Manager.
This is where my troubles start! I can not find the player anywhere on the PC. It is not recognized as a flash drive or a hard disk. It is nowhere to be found.
I then turn off the player and remove it from the USB port. I wait a couple of minutes and then reboot the player and wait a few more minutes so that it has had more than enough time to boot.
When I plug the play back into my computers USB port. Win XP Pro makes a sound like it just noticed a new USB device, but I can not find the device anywhere in the Device Manager or Using Windows Explorer.
The MP3 utility or MP3 disk format programs do not recognize the player either.
I have read one post that said I may have to format the MP3 drive from windows, but I have no idea how to do that being I can not find the device on the system.
Please Help!
  #812 (permalink)
Old 30th Oct 2007, 10:27 am
I OWE YOU A BEER AND BOTTLE OF SHAMPAIN :lol: :lol: :lol: :lol:
but there is still prop. i need to upgrade it to 002.521.180
can you help ????
  #813 (permalink)
Old 2nd Nov 2007, 6:54 am
Ok i followed the guide made by tadad1...
so i can boot the Mp4 storage..the problem is its only emitting a light with black screen when its turn on
or plugged in pc and thats weird cause..
Version Info:
SC85051A
2006/03/13
ACT_V3.5.35
not sure but i know its the same firmware and features of the Mp4
and the only thing that idont understand is FW and BIN...
when you put the full you must find the dump or bin of that player???
i already try many firmware but nothing happens...
Mp4 Name:Nasaki Nk757k
Theme: a lotus flower
  #814 (permalink)
Old 2nd Nov 2007, 10:23 pm
ok its a screen issue cause i try to play it
and it did play...
The only problem is re solder....
Thanks for this site and all the people here...even though I'm ignored...
  #815 (permalink)
Old 6th Nov 2007, 2:43 am
nab nab is offline
I can't got the adfuupdate.inf in WINDOWS folder .give me the methode to visualise ity or if you have it send t to me
thanks for your hard work
  #816 (permalink)
Old 6th Nov 2007, 5:48 am
My Mp3 Player Firmware Upgrade Tool
so slow..
It is Downloading restorable main program..
How many hours does it take?
  #817 (permalink)
Old 10th Nov 2007, 5:28 am
hi tadad1 i have "digital mp4 player" ( Model Number : SW-C205 ) ROCKCHIP 2606A. I have saved bad firmware and I have now death player (white screen and no sound) when I connect mp4 with pc it shows me disk whitch is normal used mp4 players(drive F) but when I wont to click on it then it shows me " insert disk" problem
is when I wont save new firmware then I must first change setting in mp4 "upgrade firmware" and connect USB cable. Thatīs why I cant instal new firmware ... PLS help me (PS: where can i find firmware for my mp4 player ) PLS help i have my mp4 one week .
  #818 (permalink)
Old 10th Nov 2007, 5:36 am
To get your Rockchip player into "upgrade mode" all you do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the "MENU" or the "PLAY" button and keep it held down.(try the other buttons if these dont work)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the menu key.
5) You are now in "RockUSB" upgrade mode!
6) Then just Start ConsumerUpdate and upload a working firmware and try it!
additional information can be found on Rockchip player recovery is here':-
http://www.mympxplayer.org/rockchip-...de-vt6686.html
You may like to try the firmware I used to recover my player with it's the same screen size as yours :-
http://www.mympxplayer.org/rockchip-...276-df612.html
I hope you can get your player back.
  #819 (permalink)
Old 13th Nov 2007, 10:54 am
i have sony mp4 after downloading bin format file my player is dead now pls some one help me
  #820 (permalink)
Old 15th Nov 2007, 5:33 am
helooo pls help me i have all u say and it works i have a blue screen now what i have to do i have upgrade a dump what i need fw or a dump???? i have a mp3-4 player ATJ2091H firmware:ACT2097_s72_1 9.0.43 29/04/2006 1,5screen 1gb !! i don't have the original firmware pls halp me what i have to do???
