DEAD PLAYER RECOVERY GUIDE
  #821 (permalink)
Old 18th Nov 2007, 9:39 am
I am so upset about this player so far its for my sons B-day it 2 days is the only reason I am trying to fix it.
I went through the guide. I am stuck... It recognizes it as a USB device. However it will not load the ADFUupdate.... It just says that it has no information for my Hardware.
Please TADAD1 (or anyone else) help,,, i cant afford to buy him another one
  #822 (permalink)
Old 18th Nov 2007, 4:48 pm
jukeboxjunki , go to Control Panel, and click on System.
In it, select the Hardware tab, then click on Device Manager.
Now you should see a list of hardware items connected to your computer. Look for the player, it should be highlighted with a yellow exclamation mark.
Right click on it and select Properties.
A new box should open. Now select the Details tab and in the drop down box, chose Device Instance Id.
What does the box below it display after you selected it?
  #823 (permalink)
Old 18th Nov 2007, 5:56 pm
lattesurf
This is what it says there....
USB\VID_10D6&PID_FF66\5&193F920A&0&5
  #824 (permalink)
Old 18th Nov 2007, 6:22 pm
jukeboxjunki , try using the ADFU files here http://www.savefile.com/files/1205168
Select the player under the device manager, right click and chose update driver. Then use ADFUupdate.inf file that i've provided. See if it can now install the driver properly.
  #825 (permalink)
Old 18th Nov 2007, 6:34 pm
lattesurf... I really appreciate the help here. This ADFU doesnt work either but a little different. It almost works. Says there is no section for my device.
  #826 (permalink)
Old 19th Nov 2007, 5:39 pm
jukeboxjunki , perhaps try this new ADFU file here http://www.savefile.com/files/1207727
See if it installs properly now?
  #827 (permalink)
Old 20th Nov 2007, 2:51 am
ANYKA US B 1.1 Nad Res Z USB Device
BIOS kG891 MLC V0.0.12B
Joy MP4 Player Download Frimware firmware bios
Radio , Movie , Camera 1.3M 1,3 Mpixels , 1.3Mega pixel
Games NES
Software : D B-Z-M 6.0.0L9
Hardware : DVT2.1
Audio : V0.5.29bch2
soft
Mb
AkResData.bin
kg891.bin
lang_font.bin
http://www.megafileupload.com/en/fil...layer-rar.html
http://files-upload.com/files/630324/softmp4player.rar
if your Portable Media Player have problem with software
here you can download this archive
press start button, and keep pressed, when is show
blue screen and " Insert usb cable ..." pleas insert your
usb connector cable, afther this press play button,
and you will see : press Menu if you want to low format or lowformat
...or other key .
pres left or right key ! DO NOT PRESS MENU !!!
now your computer will recognize the device us
and you will have in MY COMPUTER 3 new partition removeble
now create one new directory in your desktop from your computer,
where to make back-up your software from this new partition, (just in cases)
after you make this backup
Always BACKUP the existing firmware of your player before attempting to update
the firmware on your mp4 player. Updating your mp4 player with the wrong or
incorrect firmware will result in a DEAD PLAYER and it not booting up at all!
Always be sure that you use the correct firmware for your mp4 player only.
Updating your firmware will NOT provide you with any extra features.
It's really intended as a resource and 'backup' should the firmware on your mp4
player becomes corrupt.
copy this files after the description:
from the "partition 1" in the first of this partition
from the "partition 2" in the second partition
from the "partition 3" in the 3th partition.
http://www.mediafire.com/?6x1ix0efzmz
http://www.4shared.com/file/29824165...mp4player.html
e-mail flobucuresti(at)yahoo.com
  #828 (permalink)
Old 25th Nov 2007, 11:18 am
hi guys, i flash my mp4 player with wrong fw and now i cant turn it on i have backup file of my original fw named "dump.bin" but i cant write it back to my player and i think that file is corrupt :shock: so guys, i need help - someone have 9.1.50 firmware ? if you have, then PLEASE send it to me to the dj4stanys@gmail.com :wink: all information about my player(like ipod nano 2nd edition):
chip:
hynix
HY27UT084G2M
TPCB 723A
mbsJ0b83AA
board: K16v1K2
software(before bad fw upgrade):
MP3 PLAYER
TJD_130_02
2007-01-26
9..50
2005-01-09
  #829 (permalink)
Old 25th Nov 2007, 3:35 pm
Hang in there, i have a working 9.1.50 device, just let me get a s1clone dump from it.
  #830 (permalink)
Old 27th Nov 2007, 7:43 am
plaese i have a deid thomson lyra em2600 can it be recovered like you hva said?
