DEAD PLAYER RECOVERY GUIDE
  #851 (permalink)
Old 28th Dec 2007, 5:22 am
[img(=left|right)]http://data.yandex.ru/i?ctype=1&path=b0404134229__AM52.jpg[/img]
this is my player and here's the firmware that brings it back to life
http://www.ixtone.ua/downloads/1817W1.8_CTW500_.rar
and i wanna add that just dragging on contacts is not enough. I put the pincers and hold it for about 1-2 seconds to have shorting
  #852 (permalink)
Old 28th Dec 2007, 12:44 pm
I have a problem. When I'm trying to remove screws from my player (http://www.techgadgetforums.com/files/ibob.jpg) they are turning around, but they aren't unscrewed. What I should do?
Sorry if my English is bad.
  #853 (permalink)
Old 29th Dec 2007, 6:07 pm
Hi javier4, I've tried that but the vid & pid are always 0000.
So, is there a way to quit that usb disk blue screen in my device?
TIA,
M
  #854 (permalink)
Old 30th Dec 2007, 3:36 am
Originally Posted by Vodafone";p=&quot View Post
I have a MP4 Player like in this pictures
img137/6975/14122007zj8.th.jpg[/img][/URL]Click the image to open in full size.
and I don't know how to take out from the shell :roll: :?: :?: :?:
Hi!
It is easy First you must remove 2 screws, then plastic detail. Neatly remove the keys by screwdriver. (They are simply taped, you will nothing break Then push plate to screen upwards. http://basket23.narod.ru/DSC00092.JPG
  #855 (permalink)
Old 30th Dec 2007, 6:06 am
I have done all the process for the dead player..now I'm stuck in the blue screen, im uploading the firmware but nothing happens! blue screen is remaining.. I tried lots of different firmwares v9.xxxx but with no success.. any help?
thanks
my player is the ipod nano like.. AK1022 samsung chip
  #856 (permalink)
Old 30th Dec 2007, 5:03 pm
My computer detects the MP4 Device as USB Device but not the information AdfuUpdate.inf file, my usb device has this chain "USB\VID_10D6&PID_FF61 \ 6&1D7EFA5E&0&1" same chain that is not in the adfuupdate.inf
I can be able to load drivers?
Maybe adfuupdate.inf modify the file?
Please Help with thank you in advance
  #857 (permalink)
Old 31st Dec 2007, 1:11 am
musicman
Guest
Posts: n/a
My computer detects the player for 5 seconds then it's gone. I can see in the system tray that it's detected as a usb device but after 5 seconds it disappears. The plater shows only blue screen. Before windows explorer was able to detect it as a mass storage disc but now nada. The player is a MP3/MP4 IPOD knockoff which could play music, videos, radio and games.
  #858 (permalink)
Old 7th Jan 2008, 6:59 am
I have an MP3 player very simelar to the one displayed. In fact the only difference I notice is on the front. Yours has writing under the screen. I bought it in Sept or Oct of 2007. It hung during a Sync and has been that way since then. The computer does recognise the device but I could not install new firmware. It freezes about half way through the process. Any suggestions? What firmware and software should I be using?
  #859 (permalink)
Old 7th Jan 2008, 8:21 am
Srdls, what do you mean by a chain?
It sounds like you have a simelar problem but may know a bit more than I do. What UBS device are you talking about, the MP3 player? If so, how did you read the 'chain' from your device? It would be helpful to be able to search for a string inside the inf file to know if it was written for the device. I have looked at the inf file once but I did not understand much other than the file is written in text not machine code.
  #860 (permalink)
Old 11th Jan 2008, 9:58 am
Default mi MP4 no pasa del paso del AdfuUpdate.inf
Saludos a todos...mate mi MP4 y siguiendo los pasos de la guia llego hasta que la PC me lo reconoce, pero cuando busco el AdfuUpdate.inf me dice que no tiene informacion del controlador...que puede ser esto...
mi MP4 es un
BRIGMTON de 1GB modelo BPA-1036
les posteo estos otros datos que saque de los chips interiores por si hace falta
hynix kor
HY27UT088G2M
TPCB
746A
MTUJ507403
ATJ2091N
Gracias de antemano
