DEAD PLAYER RECOVERY GUIDE
  #861 (permalink)
Old 11th Jan 2008, 9:59 am
Default mi MP4 no pasa del paso del AdfuUpdate.inf
Saludos a todos...mate mi MP4 y siguiendo los pasos de la guia llego hasta que la PC me lo reconoce, pero cuando busco el AdfuUpdate.inf me dice que no tiene informacion del controlador...que puede ser esto...
mi MP4 es un
BRIGMTON de 1GB modelo BPA-1036
les posteo estos otros datos que saque de los chips interiores por si hace falta
hynix kor
HY27UT088G2M
TPCB
746A
MTUJ507403
ATJ2091N
Gracias de antemano
  #862 (permalink)
Old 11th Jan 2008, 10:06 am
mi MP4 es un
hynix kor
HY27UT088G2M
TPCB
746A
MTUJ507403
ATJ2091N
Gracias de antemano
  #863 (permalink)
Old 19th Jan 2008, 6:21 am
hi there.
i'm having a terrible problem with my player
i just plug it into pc and run a program which had a begin download button i click it and when i unplug my player it wasn't working
after i tried to format it but i get a message that the disk is write protected.
when i put the battery in it it shows a blank screen with light on till i take the battery off would you help me? i just can tell you what the main IC model is it is a no name player
  #864 (permalink)
Old 21st Jan 2008, 6:14 am
Code:
Using the tweezers or other metal item gently make a connection between the pins on one side of the chip. I have found this can be quite random you may also have to do it a few times.
Does anyone know why it can be restarted this way? It's amazing but I dun know why? Is there an other way that can make a dead usb wake up like that?
  #865 (permalink)
Old 21st Jan 2008, 7:45 am
shafeie,,
i'm pretty sure that u had just bricked ur player..i mean u damaged the firmware of the player...i wonder that u must have used a software named MP3 PLAYER PRODUCT TOOL ..right??actually the download button in the software writes another firmware on the player..it does not collect the original firmware of ur player...do u know wat type of your player is?
waiting for exam results.
  #866 (permalink)
Old 21st Jan 2008, 7:48 am
thont,,
do u know this method>>>
is used for the recovery of dead players..
  #867 (permalink)
Old 21st Jan 2008, 11:15 am
Originally Posted by gaboon";p=&quot View Post
thont,,
I know, that why Im asking for that! I'm not an engineer, just curious about that brilliant thing!
  #868 (permalink)
Old 21st Jan 2008, 9:00 pm
thont , what happens during the shorting process is that it creates an error signal to the memory chip. This error signal tells the memory chip to "self-reboot". Thus the computer would be able to detect the player via USB.
  #869 (permalink)
Old 22nd Jan 2008, 1:31 am
gaboon thanks for reply me
you are right that was the prog with begin dowload button. i know it's chip set name
it name like this: hynix hy27ug084g2dm
and with board ID v0.1
i found that it,s a S1mp3.
  #870 (permalink)
Old 22nd Jan 2008, 1:43 am
Default it was cryin': save me from the dark
after recover my player i just can say i owe you a beer Tadad1.
i bring it back to life by just a paperclip and those nicely imaged pics that dear admin fixed it to me to see them. and i was shocked by seeing it working again. just one problem with fw and that's the old fw had FM radio and this new one doesn't have. it's not problem till i find a fw with FM radio player
