DEAD PLAYER RECOVERY GUIDE
  #881 (permalink)
Old 25th Jan 2008, 9:44 am
Hi.
I have a problem. My MP4 don't have 2 pieces, is a only one. I can not view the chip. How can i dismantle it?
Regards.
  #882 (permalink)
Old 27th Jan 2008, 1:31 am
hi people. Ive read through about 10 pages but until i get more time for the other 50 i thought ill just ask.
My dead player is stuck on hourglass. It is detected in windows as USB 2.0 (HS) ADFU Device and WORKING CORRECTLY . Thats as far as i can get. Cant find it in explorer, cant find it in s1fwx scan and cant find it in mp3 upgrade tool/ disk manager.
cant get my fw. I cant even tell what chipset it is it has no brand, i know one day in setting i looked and it had lg firmware and the folder on device was called 1.5.
Ive tried shorting the pins and the lights go off and it reloads but just gets stuck at houglass screen again.
Any know how i can get the firmware programs to actually detect my player?
I never upgraded fw. It just stopped working one day. it is a hacked player from ebay :/ If anyone has some tips i would appreciate it. thanks.
  #883 (permalink)
Old 28th Jan 2008, 8:46 am
First, retrieve the right firmware because i think hing it again with a firmware is your last option.
If you still have other hopes, dont read the next sentence.
Try to reformat the device (shown on page 1),then use upgrade tool to flash it again with a new firmware.
  #884 (permalink)
Old 28th Jan 2008, 12:38 pm
initiate, thanks for helping.
Problem is i cant extract any firmware because the programs cant detect the device. I hit . to scan for devices and it says nothing found. Nothing pops up in explorer, but the player is listed in device manager as USB 2.0 (HS) ADFU Device.
So i cant even extract my old firmware let alone flash a new one or format the drive. How to format when its not found in my computer?
Thinking back, i think the reason this has come about is that i formatted it a week or 2 ago in fat32 instead of fat. It worked fine for a while. On the day it died/froze on hourglass, it played fine for about 7 hours at work then it froze on my way home from work whilst playing music, so i dont get it.
Now i know why people are prepared to pay more for a reliable ipod. I used to think it was just for the brand name.
  #885 (permalink)
Old 28th Jan 2008, 2:40 pm
well i think im going to just give up on this. Screw these cheap players. I just purchased a 20gb ipod off ebay for $120 aus, which is reasonable and plenty of space for me as i only use it for music.
As they say, you pay peanuts you get monkeys.
Thanks for the help anyways people.
  #886 (permalink)
Old 28th Jan 2008, 9:53 pm
Dear Mr shafeie
how are you?i have problem same as you
if possible can you call me as soon as possible
i want master reset of my Mp4 player
my cellphone number is 09143019409
my name is saloor sasan
  #887 (permalink)
Old 29th Jan 2008, 5:21 am
Default DEAD PLAYER RECOVERY
thx! thx! ....... thx! i have death player only 2 hours...You gave me the light to go on . Thanks! Thanks!
it is the best forum but, not only for me.
sorry for my english, but I am from slovakia.... but I learning this language every day.
for example I read this forum. :P
Thanks Tadad1 and other peaples here.
  #888 (permalink)
Old 8th Feb 2008, 12:27 am
i've a mp4 player nano like 1 Gb, but when i'm trying to upgrade the firmware
that was provide in the mp4 player..only the light on at the lcd but nothing happen
so i hope anybody can help me to recover my mp4 player please..
my mp4 detail:
Memory :samsung 725 k9g8g08u0m
Chip: AK1025 7f049ab 0g6
Board :kjt050fv3-m 2007.03.14
Behind the LCD : LDH128x160f09m
  #889 (permalink)
Old 17th Feb 2008, 1:15 pm
Hi!
I've follow your guide, Tadad1, but i Have a problem.
When i install a new driver by the proprieties of USB device, after show all device, there is a window that ask me the tipe of device, and only when i click next, I can select the Driver on Windows directory. The problem is that if I select a device, the driver non work. A window tell me "The specified position doesn't contain information on the hardware".
What can I do?
Your Guide is thery beatiful, but i cannot go forward.
Thank's
  #890 (permalink)
Old 22nd Feb 2008, 12:35 am
it's wrond that thing with the tweezers of the nand chip. you may BURN the chip if you short circuit the vcc+ pin with others. you must be careful to short ONLY 4 pins of the chip not random. i have a pic i found on the net i will upload it later. it works for these 4 pins as many times as you wish. also if you get an writing to flash error try to short circuit just for a secont -or- disconnect the li-on from the mp3 player for a while to cause the time function of the chip to reset. i noticed that there is a time function on some chips that prevents you from continuous flashing them. tell me if this works for you too.
