HELP!! how has fw to MP-693c-SL / 1,5'' / 1Gb / V3.5.35
Old 21st Jun 2006, 7:01 pm
Default Re: HELP!! how has fw to MP-693c-SL / 1,5'' / 1Gb / V3.5.35
nabilash, yes did. i tried all the vs of mp3 utilities.
Old 21st Jun 2006, 8:24 pm
lucianoflp, It has nothing to do with the MP3 Utilities stick with 3.68 the problem is with your player.
Connect the player to your PC turn it on and short your chip pins,
Is it still identified as an ADFU Device and does windows install the drivers automatically without error messages?
Go this far and let me know please..
Old 22nd Jun 2006, 12:49 am
Can you say, is your player detected after connecting to pc, w/out shorting i/o pins. If it goes to ADFU mode, you need to check if this pins are not connected together. I had same problem then recovering my player, but after clean pins this work excelent
Then Short i/o pins remember to stop shorting after windows detect device
Old 22nd Jun 2006, 9:52 am
tadad1 and bojer, yes the player is detected after connecting to pc and goes to ADFU mode. somtimes, after short the pin and the player detected ADFU mode, i turn off and turn on the player and it is automatically detected as ADFU, so today i clean the chip pins and tried again, but when i use the mp3 update toll to flash the fw the same messages appears. when i use the fw 3.5.37v2.1b FM.fw that i download here, and start the update toll, select the fw and before press recover firmware button the mp4 screnn turn on (black) and after when a press the recover firmware button the message "read or write device information failed!(...)" appears, but when i try other fw, other message appears, "flash is no responding".
Old 22nd Jun 2006, 3:06 pm
lucianoflp, I have uploaded a different firmware upgrade program DOWNLOAD . Open the folder and run BatchProduct.exe. If your player is not detected press the READ RECORD button. Press the REPLACE FIRMWARE button to load the firmware and then the BEGIN DOWNLOAD button to upload firmware. If the ERASE FLASH button becomes active after you load the firmware use it to erase your chip before uploading the firmware. You may then have to format the player before restoring your backup.
  #16 (permalink)
Old 23rd Jun 2006, 10:00 am
tadad1, i think the problem is the hardware... i have try every thing and nothing resolved. but, maybe the full fw what i have is not the right... i tried all of the fw on download area, now i am wainting the seller e-mail me the full fw, but he didn't know if he will can get it.... so.... i will wait this.
I tried the softer what you uploaded, i follow all the steps, until erase flash.., but the final result is REPORT => Total conect: 1 Current connected: 1 Total passed: 0 current passed: 0
really thank you by the help
  #17 (permalink)
Old 27th Jun 2006, 8:30 pm
lucianoflp, If you are still trying to find the firmware I have uploaded a full version MP-693c-SL 3.5.35 HERE I have made some modifications to it that may fix your player. Let me know.
  #18 (permalink)
Old 22nd Jul 2006, 8:35 am
I have the same motherbord and thisfiles works
There's Ipod theme too!
  #19 (permalink)
Old 8th Aug 2007, 1:27 am
i have done that with the new update program
but still i get the same message:read or write device......and flash is no responding...what should i do?
  #20 (permalink)
Old 5th Mar 2008, 9:46 am
it's possible to resend the version 2.8?
Looking for mp-693c-sl main v1.3 2005.12.14 sebas_mp Dead Players 3 20th Apr 2008 11:27 pm
Need firmware for MP-693C-SL v1.2 emotikon_ar Dead Players 1 24th Nov 2006 7:00 am
mp-693c-sl dead ;/ rydz Dead Players 3 25th Oct 2006 12:19 am
Somebody can help me? looking for FW MP-693C blumalice Dead Players 3 12th Oct 2006 7:39 am
MP-693C-SL MAIN V1.3 2005.1214 sonny Dead Players 1 22nd Sep 2006 6:33 pm
