(SOLVED) tellbook, text and games don't work! Help me
Hi friends,
I have a mp4 with 512mb from China. Last weekend I did a wrong update, but I learn how to recover the mp4 and I did that. any way, there is a problem the mp4 don't som funcions more ( text, games and tellbok ). Should I look for another firmware? Now I'm using the 693SCL-ORG. version act_v3.5.35 and I don't now if this is the correct firmware. :( Forgive-me for the mistakes. I'm from Brazil and I don't speak English very well. ;) |
fabiolelis, Can you give me a link to the firmware you are using and I will look at it.
Re: tellbok, text and games don't work! Help me
fabiolelis, I have placed the firmware on my player and have found the same problem. I think the firmware has been modifies using the "Firmware Modify" program which seems to have a bug that removes certain features. As this firmware seems to be compatible with my player I suggest you try using my original firmware dump
Here: http://www.mympxplayer.com/dload.php...le&file_id=186 If you want a diffent themed version try Here: http://www.mympxplayer.com/dload.php...le&file_id=138 Let me know if this fixes the problem. |
tada1, your firmware didn't work. if somebody have another one, please post a link.
thank you! |
by the way, where can I find anothers firmwares?
fabiolelis, Have you tried the Download Section
HERE |
yes! almost all. only this have worked.
with the others, the screen is only blue.
fabiolelis, If you have tried all the firmware here and at s1mp3.org and have had no luck I suggest you post pictures and information on your player and where you bought it from as someone else may have the same player and upload the firmware for you.
| All times are GMT -7. The time now is 1:16 am. |
