Stuck following recovery guide
Old 21st Jun 2006, 12:52 am
Default Stuck following recovery guide
Hey
So i have the nano style 1 gb mp4 player
I installed wrong firm ware yada yada yada.
So I am at the part in the guide where you use the tweezers. It works like a charm
Xp recognizes it as USB device. IT will not let me use the A..fuupdate.inf as the driver.
What can i do now? I cannot use that file and cant find a file to use as the driver - and i am one step away from where i can reflash it with a full firmware
please help
Old 21st Jun 2006, 1:50 am
mypreludeisred,
Do you have AdfuUpdate.inf and ADFUUD.SYS files in your Windows directory?
Old 21st Jun 2006, 2:04 am
The files should also be in this folder too if you have installed the AMV Convert Tool 3.68
C:\Program Files\MP3 Player Utilities 3.68\RDiskUpdate\driver
Old 21st Jun 2006, 8:33 am
Default Re: Stuck following recovery guide
Yes i do have both of those files and i do have that folder which also contains the files.
It wont let me use the .INF file as the driver it says that it doesnt go with the hardware.
Old 21st Jun 2006, 8:38 am
The message I get is
The specific location does not contain information for the hardware
Can someone please send me a driver perhaps?
I am so close to completeing the recovery but its just this one step!!
Old 21st Jun 2006, 5:35 pm
mypreludeisred, When you select install driver from disk, and then browse what file name appears in the File name: area at the bottom of the window?
Old 23rd Jun 2006, 1:18 pm
Driver name = adfuupdate.inf
Old 25th Jun 2006, 5:08 pm
mypreludeisred, There should also be a driver in your MP3 Player Upgrade Tool folder. Try that if Windows will still not install it you may need to log on to your PC as Administrator and then try again.
plz help i did recovery guide and put firmware but screen is moneybankz Dead Players 0 20th May 2008 2:42 am
Guide for Inovix IMP-64 FM recovery. skorzo Dead Players 0 27th Apr 2008 5:13 pm
Recovery Guide not working jplt44 Dead Players 1 2nd Dec 2007 5:11 pm
