Question about firmware restoration
Like many others, I tried upgrading the firmware and my mp4 player died.
I shorted the pins and revived it however, it still wont function normally. I found out that the .bin file is NOT the full firmware and that you need the .fw file and THEN update it with the .bin file. I think the problem is the .fw file (the full firmware) is not the right one. My coworker has the same model mp4 player with the same original player. Can I extract the FULL firmware off his player and use that? I know how to get the .bin file off, but now the .fw file. Thanks |
Hepnotic, It is not possible to extract a full firmware. That is why they are so hard to find. Very rarely they may be on the CD that comes with the player.
Re: Question about firmware restoration
Hepnotic
There is now a seperate section called "Full Firmware" under the [Download] --> "Firmware" section. This should have a list of full firmwares which you can use to hopefully give you a better chance at recovering your player. Good luck and let us know if it works or not. |
| All times are GMT -7. The time now is 2:49 am. |
