Plz help me -= STARTING =- problem [SolveD]
Old 3rd Jul 2006, 10:09 am
Default Plz help me -= STARTING =- problem [SolveD]
hello!
help me please
I have 3 mp3palyers half dead ( show only Starting on screen)
all mp3s palyer are fake sony ( mp3 palyer DVR ) 256MB.
can any one help me how to upgrade it
because i have extracted the firmware from another one work very well
but when i try to upgrade it the MP3 PLAYER UPGRADE Tool SAY Invalid firmware file!
Many thx !
Old 6th Jul 2006, 2:46 am
rockerenator,
Have you run the 'repair.bat' file on the dump.bin file you extracted before using it to update your player?
Old 6th Jul 2006, 3:30 am
Default Re: Plz help me -= STARTING =- problem
no i havn't run repair file
Old 6th Jul 2006, 3:32 am
rockerenator, Copy your dump.bin to the s1fwx folder and run repair.bat then try to upload to your player. The file must be called dump.bin.
Old 6th Jul 2006, 3:47 am
ok i will try
Old 6th Jul 2006, 4:05 am
oh 10x admin i have solved my problem now the 3 mp3player work fine thnx
Old 6th Jul 2006, 4:09 am
rockerenator, Excellent News
Old 6th Jul 2006, 4:53 am
rockerenator
Great news.
So running the "repair.bat" fixed the problem? Or was it something else you do to fix the problem? Love to hear how you got it fixed so next time anyone else who reads this knows what to do .
Old 6th Jul 2006, 5:13 am
Default Re: Plz help me -= STARTING =- problem [SolveD]
first i have copy and past my original firmaware(i was exctract it from a good mp3) in the same folder of s1fwx end i have run repair.bat ==> i had two fw file dump.bin & dump.bi$ :arrow: and i have upload the new firmware with update_prog_v1.48 ================> succes mp3 1st mp3 is working again ( i did the same thing for the 2nd & 3th) .... that all
thanks Admin And Mod for your help !
Old 6th Jul 2006, 5:17 am
rockerenator, dump.bis is your original unrepaired firmware. s1fwx just renames it after it repairs it, you can delete that.
Onda Clone not starting musico59 Support and How To 7 25th Aug 2010 6:24 am
mp3 player just shows starting Human? Support and How To 8 10th Nov 2009 9:11 am
ipod 8g that freeze in starting ammaoui Support and How To 1 6th Aug 2008 12:53 am
my mp3 player stops at starting RoBiNHooD Dead Players 0 1st Jul 2008 5:14 am
Video watch usb charging/starting problem madgamepro Support and How To 0 1st Apr 2008 12:35 pm
