6th Jul 2006, 3:30 pm
jeremy007,
In most cases the full version firmware will not restore you player completely, you will need to flash your player twice.
Once you are in the recovery mode you need to use a full firmware to load the boot files etc. When you have done that you can use your backup dump or try different dump.bin until you find one that works on your player.
