I think that I don't find the right firmware!
Old 26th Jul 2006, 3:46 am
bianchidavide, That is good.
When you try to then do step 2 are you able to load a dump.bin on your player?
Old 26th Jul 2006, 4:19 am
Default Re: I think that I don't find the right firmware!
tadad1, No, because when i open the upgrade tool the player turn off and turn on automatly and the program is not opened with this error: "Device switching failed, reconnect device please!"
Old 26th Jul 2006, 4:29 am
bianchidavide, Have you tried to short the chip again and try a different full version firmware?
Old 26th Jul 2006, 4:39 am
tadad1 , yes but i have the same result!
One question: is impossible that the player start to work correctly in the first step when i put an full firmware?
Old 26th Jul 2006, 4:40 am
Yes provided you find the right firmware.
  #16 (permalink)
Old 26th Jul 2006, 4:44 am
tadad1, I am losing the hopes to find the right firmware :cry:
  #17 (permalink)
Old 26th Jul 2006, 4:57 am
bianchidavide.
I am sorry I do not know why your player will not let you try to load a dump file after you install the full version firmware. Have you check the mini CD to see if there is firmware for your player there.
You could try to contact your seller and ask if he can send you the firmware or get it from his supplier. I wish I could put my hands on this thing and help you fix it.
Where did you buy it from?
  #18 (permalink)
Old 26th Jul 2006, 5:09 am
tadad1, i buy this player in april when i went in china for work and is impossible to change it!
In the mini CD inside the box is all in Chinese language :cry:
  #19 (permalink)
Old 26th Jul 2006, 5:11 am
bianchidavide, Are there any .bin files or .fw files on the CD.
  #20 (permalink)
Old 26th Jul 2006, 5:21 am
tadad1, I have already watched. there is only one file. the name is LAYOUT.BIN but is only 1 KB. Is impossible that is un firmware
Help me to find my Firmware nareshg21 Firmware 0 1st Oct 2009 10:35 am
anybody please help me find the right firmware for me vhone601 Dead Players 1 9th May 2009 11:54 pm
How to find what Firmware I need highwattage Firmware 0 18th Feb 2008 3:25 pm
I just cannot find the right firmware akiaki Dead Players 2 12th Feb 2008 5:09 am
Cant find 3.5.37 firmware fhussain Dead Players 4 8th Feb 2007 7:46 pm
