-   -   512MB mp4 plyr dead when tried 2updt wid higher firmware (http://mympx.org/forum/dead-players/33730-512mb-mp4-plyr-dead-when-tried-2updt-wid-higher-firmware.html)
Sam-TheMaster 18th Jul 2006 2:07 am
hi all mates...
my 512 player with 2 way speaker....gone dead when tried to update firmware with 3.0.35 on 3.0.27
what should I do?
its not reponsing so more...
please try to help me...
thanks to all in advance
Sam-TheMaster 18th Jul 2006 2:08 am
http://www.mympxplayer.com/album_showpage.php?pic_id=58 this is image and details for player
tadad1 18th Jul 2006 5:55 am
Sam-TheMaster, Is your player still recognised by windows and can you open it in explorer?
Sam-TheMaster 18th Jul 2006 6:05 am
tadad1 not its not recognized by my windows....
thanks in advance...
from sam...
CHETs 18th Jul 2006 8:04 am
HAI guyz... i'm new here.. mine is also new prob.my player is also as Sam-TheMaster. http://www.mympxplayer.com/album_showpage.php?pic_id=58 this is image and details for player d big kick is.. it happened just after a day i brought it from shop.. but good is it can be recoganised well in windows n all songs in it can be played but screen is always blue.. i cant see any viseo/animation/menu potions.. this all happened when i upgreaded its frimwere.. can any 1 send me it's working back up frimware.. plz plz
tadad1 18th Jul 2006 7:18 pm
Sam-TheMaster,
I am sorry I am not familiar with your player generally the chip you are looking for is the largest one on the board.
I am also not familiar with the version numbers you quote.
I know of 3.5.35, 3.5.37, 3.2.13 and 3.2.16.
All I can do is suggest you folow the DEAD PLAYER RECOVERY GUIDE, and trying different firmware until you find one that works with your player.
tadad1 18th Jul 2006 7:22 pm
CHET, If you know the version numbser of your original firmware all I suggest is you keep trying random files till you find the one that suits your player.
If your player stops responding and is no longer recognised by Windows you will also need to follow the DEAD PLAYER RECOVERY GUIDE.
Sorry guys there is no quick fix if you have not backed up your firmware it is all just trial and error till you get it right.
Sam-TheMaster 18th Jul 2006 9:25 pm
Oh...No tadad1 Please do something....its not mine player...i just thought just to change a software in friends player but somehow i update it with higher firmware...You just suggest me your recovery guide is based on clone NANO..I have sony clone player...now tell me whats that IC functions exact...
i am electronix engineer and working for gsm mobile repairings.....so please try to gice some explantion....
please pm me on yahoo gaurav_sam33@yahoo.com
or you can also contact me on msn
gaurav_sam33@msn.com
thanks in advance....you are really a genius person..
try to solve mine prob...
tadad1 18th Jul 2006 10:05 pm
Sam-TheMaster
I can only give you advise based on my own experience. The only player I have recovered is the Nano clone. The steps I took to achieve this are all in the DPRG. The chip that I reset using the process is the memory chip in my case a Samsung 1GB nand flash.
If your player is not being recognised by windows you can not use the upgrade utility to re-flash the firmware of your player. The only way I know to do this is to short the memory chip which resets it. Windows will then recognise the player as a ADFU device and the upgrade utility will announce that the player is in recovery state and you will need to load a FULL VERSION FIRMWARE. Once you have done this you can reload a backup dump.bin.
There are so many variations of firmware and players that it is impossible to tell you which firmware is right for your player so you must try different ones until you find one that is compatible with your player.
The player will have had a driver CD with it, on some you may find a copy of the firmware as a .bin or .fw file but this is not always the case.
Sam-TheMaster 18th Jul 2006 10:58 pm
oki..i ll try and post results soon...should i send you video for that?
thanks
