[Solved] Dead player... or not?
Old 18th Jul 2006, 6:05 am
Default [Solved] Dead player... or not?
I recently got a '8GB' mp4 player as a gift. Couldn't get it to work properly so I formatted it and I ended up getting a 256MB player. Problem now is that I can't turn it on but my PC can detect it and I can transfer my files into the player. Is my player dead or is it something else.. maybe the LCD? Need help!
Old 18th Jul 2006, 7:29 pm
shah,
Check the CD that came with your player there may be a copy of the firmware on it. It will be a .bin or .fw file. If it has one or you have a backup dump.bin you could try to reload your firmware. If you have no backup of your firmware and you know the right version number you can try ones from the download section.
This process could make the problem worse though as you may end up with a player that no longer works and is not recognised by Windows in which case you will have to follow the DEAD PLAYER RECOVERY GUIDE to get your player going again.
http://www.mympxplayer.com/viewtopic.php?t=567
Old 19th Jul 2006, 1:18 am
Default Re: Dead player... or not?
I tried to follow the recovery guide with no success. I can turn on my player but I can only see a blue screen. Windows did not detect my player.
The label on the chip says:
Hynix KOR
HY27UF082G2M
TPCB 618A
M95DM502Y
Hope this helps.
Old 19th Jul 2006, 2:02 am
shah,
What happened when you crossed the chip pins?
Did Windows install the AdfuUpdate driver?
Did the player go into recovery mode?
Old 19th Jul 2006, 4:39 am
tadad1,
nothing happened when i crossed the pins. Do i have to connect any random pins together or are there any specific pins to be connected? I'm starting to give up and try to fix another device with the same problem.
Old 19th Jul 2006, 4:44 am
shah, It can be random I have even done it from opposite sides. The only thin I can think of is the player must be switched on and connected to the PC when you do it. Shorting the chip will generally make the screen flicker.
Old 19th Jul 2006, 6:13 am
tadad1,
I tried the recovery guide again, this time on the opposite side of the chip and once the screen flickers, it's one smooth ride... Player's up and running and now i can try fix the other one. Thanks and bravo to this site!!!
Old 19th Jul 2006, 6:24 am
shah, That's great news, I hope the other player goes as well.
[solved] Help recovering dead Rockchip player ghost_pilot Dead Players 6 31st Dec 2008 9:31 am
[solved] Dead player from stoneswei (act_v9.1.52) Skill Dead Players 3 18th Dec 2007 8:35 pm
[SOLVED]Dead Player - EAG-25-A4 evilglist Dead Players 7 16th Sep 2006 12:35 pm
[solved]DEAD PLAYER 1GB NANO clone klappi Dead Players 15 17th Jul 2006 7:08 am
[solved,bought a new one =P]Help with my dead player lookez Dead Players 8 18th Jun 2006 5:28 pm
