-   -   Flash not responding (http://mympx.org/forum/dead-players/33777-flash-not-responding.html)
bober 20th Jul 2006 8:08 pm
Hello, im trying to use full firmware for recovery my dead player. PC detects it as ADFU server, but when im trying to load full firmware i received Error with message Flash not responding. Can anybody help there?
tadad1 20th Jul 2006 8:44 pm
bober, You may need to format the player first. Also what version of the MP3 Player Utilities are you using?
bober 20th Jul 2006 8:58 pm
Re: Flash not responding
I just download 4.03 ver. How can i format it, if windows can't see player as USB, just as ADFU device?
tadad1 20th Jul 2006 9:36 pm
bober, Try turning the player off and then back on. When you start the MP3 Player Upgrade Tool does it detect that your player is in recovery mode?
bober 20th Jul 2006 9:47 pm
Yes it does. And after i try to use full firmare i received 2 messages Flash is write protcted or Flash is not respoding.
tadad1 20th Jul 2006 10:25 pm
bober, Do all full firmware you try give you the same message?
bober 20th Jul 2006 10:29 pm
Yes, i tried to use 5 full Firmwares, all give that messages
tadad1 20th Jul 2006 10:44 pm
bober. try downloading the commercial upgrade tool from here
http://www.mympxplayer.com/dload.php...le&file_id=234
Some have found it more successful when having difficulties.
