My player is half dead how do i revive it
Old 21st Jul 2006, 5:34 pm
Default My player is half dead how do i revive it
To any one that can help
I Purchased a mp3/mpx/mp4 on ebay when i got it, it had a flower theam and i wanted to change it i googled searechen and found this web site unfortinatly i mased up my mp3 or wtv u wanna call it. Its screen was black but it still played music and did all the functions i then found a firmeware theat fixed it in a way now i can see my screen but in the middel its cut off and the top is 2 but the images i can see are negative (meaning what is sopost to be black is wihite)
any 1 plz help!!!!!
Old 21st Jul 2006, 5:57 pm
ghov, It is still not the right firmware, if you did not backup your original you are just goin to have to try any you can find till you get the right one.
Old 27th Jul 2006, 8:43 am
i tried every singel firmwere on this web site i have purchased another mp3 with only one diference its 1 gb more should i use that firmwear to fix it
if u say no, can u plz tell me wich softwear is needed(i have a 1 gb nano clone its called digital player mp4
Old 28th Jul 2006, 1:15 am
Default Re: My player is half dead how do i revive it
What is your board id number ? if it's MP-693C-SL MAIN V1.3 2005.12.14 i might have a FW that can help you....it fixed my chi-pod, although i lost some of it's features (games, ebook, tel book).
Old 28th Jul 2006, 1:37 am
ghov, Your new player may have completely different firmware dispite that they look the same, and unfortunatly it is not possible to point you to a firmware that will fix your player. There are so many different variations now that it is a bit like finding a needle in a hay stack.
Old 28th Jul 2006, 1:46 am
you're not wrong....even knowing the board id, screen number & battery types still won't help you in finding the EXACT firmware you need, but that info does help us help you
Old 1st Aug 2006, 2:56 pm
when i go to the upgrading program its says d name s1 mp3 player thats all i now about it if u need more info tell me were to find out more
Old 1st Aug 2006, 4:38 pm
ghov, If you have already flashed your player there is no way to find what the original firmware version that was on your player because it is gone and the only way to look it up is on the player in Settings>Firmware Version. There are new firmware uploaded to site most days you need to keep tryin different firmware till you find the right one for your player.
Half Dead Player... droral Dead Players 13 4th Aug 2008 8:01 am
Half-Dead Tylex MP4 player arzakem Dead Players 0 24th Dec 2007 9:27 am
mp4 player half-dead hellboywb Dead Players 35 13th Oct 2006 5:20 am
Rare Half Dead Player wirklich Dead Players 0 15th Sep 2006 7:45 pm
My half dead player ^^ Dead Players 12 14th Jun 2006 9:32 am
