accidentaly remove the usb cable during firmware update
Old 26th Jul 2006, 3:43 am
Default accidentaly remove the usb cable during firmware update
sir, please help me, i upgraded my firmware of my mp4(sundisk SD-M5300) after, i accidentaly remove the usb cable and suddenly shutdown my player, now deadset, never been switch on, blackout in short, tnx
Old 26th Jul 2006, 3:48 am
badzlibid,
Do you have a backup of your original firmware?
Do you know what version it was?
What did the menu's look like?
What size is your players screen 1.5 or 1.8?
Old 28th Jul 2006, 2:17 am
sir, i dont have backup, my player is sundisk i think 1.8 screen, i use mp3 player utility 1.45
Old 28th Jul 2006, 3:19 am
Default Re: help please
Have a look at tadad's - DEAD PLAYER RECOVERY GUIDE from here.
Please follow that and see if you can get your player back to a good working state.
Please take the time to follow the instructions as this will help relive your player if all goes well.
Good luck.
Old 28th Jul 2006, 3:22 am
Default Re: accidentaly remove the usb cable during firmware update
no backup? uhh sounds bad... seems like you have to try a couple of firms if you don't know your firmwarespecifications and where to get it. hmmm i had to start the update-tool really fast when my pc recognized the player because it disappeared some seconds later again. and i had to try it a lot of times, but i had a backup of my firm.
Samsung yp-z5 USB data Cable//losing usb cable P@inKuler Support and How To 2 5th Feb 2009 1:38 pm
how to remove record at the firmware? clas1070 Support and How To 1 6th Dec 2008 12:05 pm
usb cable for mp4 eltocado Support and How To 3 13th Apr 2008 1:09 am
Remove hack on ipod nano clone 9.1.51 firmware? reactos Support and How To 1 25th Sep 2007 2:08 am
MODIFY A FIRMWARE TO REMOVE FUNCTION “AMV PLAYER" binertorres Mods and Themes 3 25th Jul 2007 9:58 am
