(solved) SC85051B mp4 2gb nano clone Firmware
Old 26th Jul 2006, 6:49 pm
Default (solved) SC85051B mp4 2gb nano clone Firmware
SC85051B
2006/03/17
ACT_V3.5.35
Using "MP3 Player product tool" to update the firm ware, i tried to extract and back up my original firmware but when i put it back in the screen is painfully bright. otherwise works as normal.
Can someone help me acquire a firmware that will work of any version that will A not randomly corrupt the files on the device (which is why i started into this anyway), and B. will have the screen dark enough to read?
Old 26th Jul 2006, 6:58 pm
Also, the screen is mirrored in addition to being too bright.
Old 26th Jul 2006, 7:17 pm
Default Re: (solved) SC85051B mp4 2gb nano clone Firmware
It was the loader. Useing the upload method described in the knowledge base solved my problem. In my opinion "product tools 4.19" should be pulled from the downloads section.
Old 26th Jul 2006, 7:25 pm
Innomen, Are you using your backup or one you downloaded?
You may be able to adjust the brightnes by loading the firmware into Firmware Modifier HERE thet has a contrast adjustment then save and reload to your player. If the images are mirrored this can't be fixed the firmware is not the right one for your player. The only firmware I can direct you to are in the download section if someone with the same version reads your post they may upload it for you.
Old 31st Jul 2006, 7:27 am
tadad1 or Innomen, I view that innomen have my old firmware.
Where i can take this full firmware?
SC85051B
2006/03/17
ACT_V3.5.35
Please, can you give me the lik?
Old 31st Jul 2006, 4:41 pm
bianchidavide, Send a PM to Innomen he may send the firmware to you if you give him your email address.
Old 31st Jul 2006, 4:43 pm
Innomen, Sorry to hear you had a problem with the product tool. It is odd because it is what I use to upgrade my firmware all the time and it has never given me any problems. Glad you got your problem sorted though.
[solved]Mp4 nano clone (2GB) still doesnt works mrpragay Dead Players 5 4th Oct 2006 7:28 am
[solved ] eBay Mp4 nano clone (4GB) firmware wanted rad Dead Players 8 2nd Oct 2006 9:48 pm
[SOLVED] Help with 2gb Nano clone PLEASE ThePhantom Dead Players 8 17th Sep 2006 1:42 am
(Solved) Nano Clone Frozen! Help please. Jade Enigma Dead Players 4 1st Aug 2006 10:37 pm
[solved] Using a nano clone with a Mac bluaerio Support and How To 4 10th Jul 2006 5:29 am
